1999 vettes?
Old Aug 29, 2012 | 05:29 PM
AllanE's Avatar
AllanE
Navigator
Default 1999 vettes?
Do they give any mechanical/computer problems compared with the 2000? I'm looking to buy a vette and can't seem to find a 2000 vette so I might settle for a 99 not sure, but if I do I want to know if it gives any extra problems compared with the 2000.
Thank you
Allan
Old Aug 29, 2012 | 05:53 PM
AllanE's Avatar
AllanE
Navigator
bump, really need an answer
Old Aug 29, 2012 | 06:45 PM
abflyboy's Avatar
abflyboy
Originally Posted by 8VETTE7
I personally would look for a 2001 rather than any year earlier. Some key failing components are either repairable or still available for 2001 and newer compared to pre 2001. One key example is the EBCM that controls anti-lock brakes and Active Handling.
Old Aug 29, 2012 | 07:38 PM
Old Horsepower's Avatar
Old Horsepower
I bought my 99 three years ago and everything works perfect. I had a few electrical problems but a new battery fixed that. Has 60k miles. My GF has 04 and it has all kinds of problems. Active handling and ABS messages. Power seats stop working. Overheats. Its always something. I don't know if one year is really better than another. Some parts are cheaper on the newer ones. I think it depends more on how previous owners maintained it. Good luck!
Old Aug 29, 2012 | 08:02 PM
NukeC5's Avatar
NukeC5
It would be best to see if the records show work done, like the column lock issue being taken care of etc. I have a problem free 99. It seems to have been well taken care of.
Old Aug 29, 2012 | 08:47 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree with 8Vette7 too. The later ones have some improvements and some things may be repaired easier and/or have parts availability.
However, I have 2 '99s and have not had problems that are unique to the early ones.
I put a column lock bypass on both cars and had a harmonic balancer wobbling on one. Both of these issues are not confined to the early years.
I am doing the upgrade to the later TPMS and key fobs (the later TPMS sensors are less expensive), but I found a couple good deals and it is less expensive to convert the system than just buying the early replacement sensors.
Yes I think the later ones are the ones I would look for also, but if you find a nice early one I wouldn't be scared off. That's why I bought them when I found ones I liked.
Old Aug 29, 2012 | 09:38 PM
corv1998's Avatar
corv1998
I found a 98 a few years ago that has been nothing but a fantastic car. As with anything you purchase used it must be carefully examined . The only problem is i find my-self putting many mods on car, headers ,suspension ,ccw rims , a&a supercharger , now i would not sell car as it fits me perfectly , 500hp of goodlooking fun. Just be careful when looking , do not get caught up in the moment of buying a sports car, you have gone this long without one a little longer wont kill you
Old Aug 29, 2012 | 09:55 PM
PaulaH's Avatar
0PaulaH
Former Vendor
I had a perfect 98! Never a problem with it. Kept it for 9 years.... Loved that car!
Old Aug 29, 2012 | 10:11 PM
happiedazs's Avatar
happiedazs
In my opinion, the newer C5 the better --- but whatever year you settle on, buy one with NO MECHANICAL MODS otherwise you could be spending most of your time chasing gremlins and trying to get your car to run right instead of enjoying your ride ---- spend some time reading the many threads on the Tech/Performance section of this Forum.
Good Luck
Old Aug 29, 2012 | 10:56 PM
gunga68's Avatar
gunga68
I've got one and love it.
Old Aug 29, 2012 | 11:45 PM
Chilliwack vettes's Avatar
Chilliwack vettes
I wanted a '98 because of the Pace Car edition. Otherwise I would have got a newer one. BTW, my '98 is problem free except for the regular C5 stuff (HVAC etc).
Old Aug 29, 2012 | 11:57 PM
cadmando18's Avatar
cadmando18
I bought my 2001 and the only problem I'm having with it is that darn P0410 code. I'm chasing that one now. I really think it depends more on how the previous owner(s) took care of the car. As with any used car, educate yourself, and find out as much as you can about the car you want to buy.
Old Aug 30, 2012 | 09:53 AM
I had a '99 for about a year - no problems back then. I had my '00 for 7.5 years and had a few problems (three rear diff output seals replaced, seal between tranny and diff replaced, oil consumption that needed new rings installed - all done under warranty). But I loved the car. My '03 has not had any problems in the 3 years I have owned it. I would agree with the above that if your budget allows and you can find a well maintained car, look for an '01 and above. The parts availability issue is beginning to hit all the C5s but at least some critical components are still available or can be repaired.
That said, if the '97-00 cars are what your budget allows, then just thoroughly check the car over - while it is no guarantee that things won't go wrong, you would have done your best to try and spot things before you buy.
Old Aug 30, 2012 | 10:26 AM
NukeC5's Avatar
NukeC5
I really think you will find that a cars a car. You can get lucky or get a money pit from any make, model, or year. There are so many things that can go out or need replaced on every car. Just in this short thread you can see different problems from all different years. Most are not year specific and can happen to any car.
Old Aug 30, 2012 | 03:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The 2001+ cars have the most C5 upgrades. The EBTCM for 2001+ is easier to find if it goes bad.
The EBTCM for 97-2000 are NO LONGER available thru GM and no one aftermarket can repair them.. You can only hunt down a good used module. $$$$$$$$$$$$$
Like others stated... purchase whats available and fits the budget.
Where do you live??
Bill
Old Aug 31, 2012 | 09:36 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I happen to think that the '99 was the best year but changes and upgrades in later years is something to consider.
Old Aug 31, 2012 | 11:06 AM
f6john's Avatar
f6john
All 97 thru 2000 cars should be recalled and sold for parts and we should be given vouchers for a ZR1 in the color of our choice!
To 1999 vettes?
