The yellow wire runs from Fuse 5 (ABSTRANS) and the Red wire from the Battery relay panel (+) both run to the aftermarket relay/fuse panel.
________________________________________ _______________
This relay block wiring is:
Orange to the 25 amp fuse and from the fuse to a splice with a blue or pale green wire in the large bundle behind the fans.
Black dual conductor to what looks like a sensor stuck into the back of the radiator.
Black single conductor to ground
Blue wire open
Green wire open
Any ideas on what this mod is? I appreciate the help. Just a few notes, I cut the cable ties and opened the bundle up that's why the wiring looks like a mess. Also, the air filter is out for cleaning. That's why the intake is out of place.
Thanks for the information, I really appreciate it. I'll do a web search and see if I can read up on it.
So do I really need to cut the fans on at a lower temp on my stock 2004or should I rely on the engineering of C5? Unless a certain engineer who helped developed the C5 tells me different, I think I will leave mine alone
I don't think I would've installed it but since it came with the vert, I wanted to understand what it was and how it worked.
alrighty then...that explains it...now take it back to stock because you don't need it...
Just noticed your wonderful '99 Torch Red Vert looks just about identical to my '04...can't tell them apart other than the wheels
