Muffler Removal
Old Sep 10, 2012 | 10:52 AM
tentuna's Avatar
tentuna
Default Muffler Removal
How high do you have to get the rear end off the ground to remove the mufflers on a C5, assuming the rear stabilizer is removed. On jack stands. looking at it I can get it up ~2ft, broke the bolts loose so that should not be a problem just don't want to start the removal if I need more height.
Old Sep 10, 2012 | 11:09 AM
GoBallsDeep!'s Avatar
GoBallsDeep!
from ground to the bottom of the rear bumper cover needs to be 40"
Old Sep 10, 2012 | 11:16 AM
tentuna's Avatar
tentuna
Have to get on my friends to my friends lift, no way jack stands
Old Sep 10, 2012 | 11:27 AM
tentuna's Avatar
tentuna
Originally Posted by 8VETTE7
If your putting on an after market Cat Back system then just use a sawzall or chain cutter to cut the over the axle pipes. The stock muffler set up is worthless for resale (except for the Z06 setup). The after market setups come with two piece over the axle pipes and those can easily be installed on jack stands.
What I am going to is a Ti setup out of a Z06, looks like new so I need to get the 40"
By the way are the bolts standard 15 mm, when I pulled them I did not take them to Sears Hardware to match?
Old Sep 10, 2012 | 12:58 PM
bumble-z's Avatar
bumble-z
Re use the stock bolts & nuts.
You may need to buy new gaskets that go be tween the catback & H or X pipes. Gasket part # GM#10276792
Being you have a GM Ti system to install, there is no need to destroy the old system.
( I hate destroying perfectly good parts)
Take it out as single piece .
Old Sep 10, 2012 | 01:21 PM
tentuna's Avatar
tentuna
Bought gaskets at NAPA they crossed to an exact match
As far as taking them out as one piece I feel the same way, I'd rather give them to someone that cut them up.
Any idea about the 15 mm bolts?
Old Sep 10, 2012 | 01:26 PM
bumble-z's Avatar
bumble-z
What do you want to know about the 4 bolts?
Old Sep 10, 2012 | 01:33 PM
tentuna's Avatar
tentuna
Are they standard 15mm thread, I want to replace when I change over to the Ti exhaust
Old Sep 10, 2012 | 02:11 PM
bumble-z's Avatar
bumble-z
The head of the bolt is 15mm (wrench size)
The bolt is 10 mm (diameter) x30mm (long) -1.5mm (thread pitch)
Old Sep 10, 2012 | 02:14 PM
tentuna's Avatar
tentuna
Geeze.
Old Sep 10, 2012 | 02:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your going to attempt to jack the back of the car up that high,, you are going to have to drive the front wheels up on some wood ramps first. If you dont,, the front spoiler will get smashed up on the floor way before you reach minimum muffler removal height!
Trust me! Been there!
Old Sep 10, 2012 | 02:28 PM
tentuna's Avatar
tentuna
Yeap, realize that, I will wait for the lift, then 15 mins later switched, bolts already pulled, lubed and re-torqued, so they will come right out, just clean flange and put the Ti exhaust in
Old Sep 11, 2012 | 02:08 PM
94centennial's Avatar
94centennial
i remove the stock mufflers from my 2001 conv without cutting. i only raised the car about 15".
Old Sep 11, 2012 | 02:12 PM
tentuna's Avatar
tentuna
What, I never heard that before, how did you do it drop the rear cradle?
Old Sep 11, 2012 | 03:01 PM
94centennial
i have a drive on ramp/lift that uses a floor jack to raise the rear portion after the car is driven on. 15" is a guess. it may be a couple more inches. When thre car was on the lift, it was level, not dipped down in front like raising only the rear end. i recall, it was very tight and thought about cutting. But i was able to remove the muffles without cutting.
Old Sep 11, 2012 | 09:13 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Is that a Kwiklift?
Although having a lift doesn't help the OP, I am curious if a Kwiklift gets the car high enough to do mufflers?
Old Sep 12, 2012 | 12:57 AM
PUMP03's Avatar
PUMP03
Oldtimer
Originally Posted by QCVette
Is that a Kwiklift?
Yes it does.
To Muffler Removal
Old Sep 13, 2012 | 01:14 PM
94centennial
it is a Kiklift. it's pretty neat unit. but i'm thinking of selling it, because i've picked up a couple motorcycles and i'm running out of space in the garage.
Old Sep 13, 2012 | 01:16 PM
bumble-z's Avatar
bumble-z
Old Sep 17, 2012 | 08:48 AM
94centennial
$700, i think i paid $1,100.
