Alignment Specs
Old Sep 16, 2012 | 01:52 PM
WKMCD's Avatar
WKMCD
FWIW: Before coilovers and the 345's on the back, I always ran 04 Z06 specs. Seemed like a reasonable comprimise and didn't tear the tires off the car.
Old Sep 16, 2012 | 08:00 PM
01vetter's Avatar
01vetter
Default Toe out?
Originally Posted by AU N EGL
Not with 1/32"
Not loose but precise steering input.
Most ppl are just use to poor alignments and steering response.
You could run 0 Toe and 0 neg camber, plus 6.9* Right front caster and 6.0* left front. too accommodate for right lane highway driving and road camber.
However, when you get to good flat road, with a few twistie, you find out how so called "Good" highway alinement is really poor for driving.
I had my car with a little toe out and found that it wandered on the highway. See post 20 for some explanation about why (wanted to follow cracks and ruts). Also, unless you have poly bushing you will get even more toe out at highway speeds due to flex in the bushings.
I suggest reading this short description of the effects of alignment geometries:
http://www.ozebiz.com.au/racetech/theory/align.html
Here is a paragraph summarizing why Toe Out results in highway instability:
"If the car is set up with toe-out, however, the front wheels are aligned so that slight disturbances cause the wheel pair to assume rolling directions that do describe a turn. Any minute steering angle beyond the perfectly centered position will cause the inner wheel to steer in a tighter turn radius than the outer wheel. Thus, the car will always be trying to enter a turn, rather than maintaining a straight line of travel. So it's clear that toe-out encourages the initiation of a turn, while toe-in discourages it."
When my car has some toe in it tracks better. Anyhow, this works for me. GM specifies a slight Toe In for all around driving
Old Sep 16, 2012 | 08:11 PM
01vetter's Avatar
01vetter
Default Toe out wears inner edge info.
Originally Posted by lionelhutz
Instead of just making claims why don't you explain why? Toeing in 45* would give the wheels some level of camber around -4* so the wheels would be riding heavily on their inside edges. So, why would the tire wear on the outside edge? Also. I had excessive camber and toe-in on my car and it was eating the inside edges off the tires which is contrary to your statement.
May I suggets that you read this:
Here is a paragraph from this article:
"For minimum tire wear and power loss, the wheels on a given axle of a car should point directly ahead when the car is running in a straight line. Excessive toe-in or toe-out causes the tires to scrub, since they are always turned relative to the direction of travel. Too much toe-in causes accelerated wear at the outboard edges of the tires, while too much toe-out causes wear at the inboard edges."
So if you combine toe out with negative camber you can say by-by to your inner edges! Ask me how I know!
Your wear depends on the how aggressive your camber was set. You could have had a large negative camper and a small amout of toe in. Remember that you loose toe in at highway speeds due to flex of your bushings. Also, if you take a lot of tight corners (like in parking garages) you will get even more inner edge tire wear.
Hope this helps!
Old Sep 16, 2012 | 10:47 PM
lionelhutz's Avatar
lionelhutz
The link didn't give any reason why...
Well, you can also say by-by to the inner edges with toe in. My car was at -1.1* camber and 0.4* toe and it destroyed the inside edge on the old tires that came on the car.
Old Sep 16, 2012 | 10:49 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by RonSSNova
Toe numbers stated elsewhere in this post are more like .01deg, which has to be near 0. Solo explained 0 to toe out will make the car turn in fast, but not be good for ruts.
Yes, my numbers should have been 0.1* each and 0.2* total.
Old Sep 16, 2012 | 10:54 PM
01vetter's Avatar
01vetter
Lionelhutz, are you running Goodyear EMTs (stock tires)? If yes, they don't like large camber due to stiff sidewalls. I found that even -.2* caused excessive inner tire wear. -1.1* would be a lot of camber for stock run flats.
As for the reason why toe out wears the inner edge, tires have flexible sidewalls. When you toe out the tire rolls over its sidewall slightly. This changes the tire patch so that more inner edge is on the road than outer edge. You then drag the tire and this scrubs more rubber off the inner edge than the outer edge. The reverse is true for toe in.
Old Sep 16, 2012 | 11:49 PM
RonSSNova's Avatar
RonSSNova
Whew! Thanks. I thought maybe my car was set up like a road grader.
Ron
Old Sep 17, 2012 | 12:30 AM
abflyboy's Avatar
abflyboy
Default Pfadt Racing alignment specs
Pfadt Racing alignment specs (these are the specs I use):
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
Be sure to note that the negative number for toe values in the Pfadt specs is toe IN
My current alignment numbers for my DD 2000 Coupe are:
Front camber -0.7 left and right
Caster +7.4 left and +7.8 right
Front toe 0.0 left and right to allow for bushing flex slight toe out
Rear camber -0.4 left and right
Rear toe 0.1 left and right TOE IN
I have ZERO rut hunting problems with this set up and the car is stable all the time.
Most modern tires are designed to accept light negative camber angles with no unusual tire wear. This is due to the nature of vehicles manufactured in the last 15 or so years running negative camber numbers from the factory.
Heck, I've been running my 1978 Malibu at -0.5 camber and 1/16" toe OUT for the last 20 years as a daily driver. ZERO abnormal tire wear. Except for the back tires. They run out of tread pretty quick.
But that tread wear is EVEN across the tires.
HTHY
Old Sep 17, 2012 | 01:12 AM
RonSSNova's Avatar
RonSSNova
I invite you to drive the studded tire rutted roads of Portland Oregon. (it rarely snows here, go figure)
Your car will try to change lanes all by itself. I guarantee.
Ron
Old Sep 17, 2012 | 12:19 PM
abflyboy's Avatar
abflyboy
Ron
Old Sep 17, 2012 | 07:07 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
HTHY
Very close to what I run also. I have no problems, happy with the way it handles. I run -.9 camber, a little more aggressive than yours.
Old Sep 17, 2012 | 09:30 PM
AU N EGL's Avatar
AU N EGL
Guess I am just use too high speed corner driving.
Funny part is my tire wear is very even.
Old Sep 17, 2012 | 11:02 PM
  #33
RogerT's Avatar
RogerT
Default Alignment
I run one degree negative camber on all four corners with non-runflat tires on my 2001. 22,000 miles. No adverse tire wear.
You want some toe-in on both ends of the car for stability.
Good handling on the street, autocrossing and on the track.
Hope this helps.
Roger T
