Cam swap
Old Sep 18, 2012 | 09:59 PM
butch2000's Avatar
butch2000
Default Cam swap
Hi , is there anwhere here that details a cam swap ? on a LS-1 ? I have not had the chance to do one yet , have done many small blocks in my day , and can a cam swap be done on a C5 Vette with out pulling the motor ?
Old Sep 18, 2012 | 10:27 PM
AFTRBRNR's Avatar
AFTRBRNR
Yes it can be done.
You will need to remove the front bumper and the fan and radiators.
I'm sure there is a nice thread somewhere on here that details it.
Old Sep 18, 2012 | 10:46 PM
lucky131969's Avatar
lucky131969
Originally Posted by AFTRBRNR
Yes it can be done.
Ok, you got me. Why does the front bumper have to be removed for a cam swap?
Old Sep 18, 2012 | 11:38 PM
FRITZM's Avatar
FRITZM
Default Cam
Try this.
http://www.ls1howto.com/index.php?article=1
Old Sep 19, 2012 | 02:02 AM
NukeC5's Avatar
NukeC5
That link is a good one^^^
The condenser does not need pulled. Just moved as best as possible. You don't have to disconnect it and lose the freon.
I have been planing a cam swap too. It takes loads of research on the parts needed if you are going to be doing it yourself. Lots of info on this forum. Be patient and do some research and searching.
Old Sep 19, 2012 | 04:55 AM
vettenuts's Avatar
vettenuts
Use caution with LS1howto.com when following the methods on that site. Of particular concern is the removal and installation of the harmonic damper (pulley) whose methods have been the source of many damaged crankshaft threads. That site also plays is very loose with bolt tightening specifications and improper rocker arm installation methods.
Service Manual provides the correct procedures and torque values.
Old Sep 19, 2012 | 10:10 PM
AFTRBRNR's Avatar
AFTRBRNR
Sorry, I hadn't slept in a while... I meant to say the hood. You just need to pull everything in the way just above the crank to get a clear shot.
Old Sep 19, 2012 | 10:29 PM
blownnastyc5's Avatar
blownnastyc5
you dont have to remove the hood, would make it easier but not required. Your biggest obstacles will be getting the harmonic balancer bolt out then the balancer itself, ofcourse after taking out the steering rack so you can get to the bolt. If your handy with tools, have the RIGHT tools and time you can do it yourself.
Where are you located?
Old Sep 29, 2012 | 10:22 PM
James2002z06's Avatar
James2002z06
Default Cam
Why only a cam????
Old Sep 29, 2012 | 10:36 PM
butch2000's Avatar
butch2000
well it obvious the heads will come off with the motor in the car ?
Old Sep 29, 2012 | 10:42 PM
dblerman's Avatar
dblerman
Yes, heads can come off with the engine in the car.
.................but, if you have to ask that then you shouldn't be attempting a cam swap until you pick up some service manuals.
Old Sep 29, 2012 | 10:44 PM
James2002z06
Default Cam
If your going to do a cam and head swap there are other things to consider
Injectors with new heads
New oil pump
New timing chain
Springs - lifters
Cold air intake
Headers
Exhaust
I can keep going but they will get you going
To Cam swap
