A little help
Old Sep 29, 2012 | 09:43 AM
kingvjim's Avatar
kingvjim
Default A little help
Yesterday my car started idling a little rough and I heard a vacuum leak. This morning I found the culprit and want to fix it, but what do I tell the guy at the parts counter that this is? (All my previous expierience is on old 60's and 70's V8's so don't laugh)
Thanks in advance.
Old Sep 29, 2012 | 11:12 AM
kingvjim's Avatar
kingvjim
LOL Nevermind. Ok so it's the PCV Valve and a boot. Looked to me like the hold down wire was a ground......LOL So that little rubber boot was ridiculously expensive, so being the thrifty dude that I am I just used a piece of rubber fuel line off the roll that I just purchased to redo the lines on my 79 T/A.
NukeC5's Avatar
NukeC5
That is the PCV hose from the PCV valve to the intake. It is not a special line. You can pull it off the intake and valve and cut an equal length and diameter rubber tube to go back in.
Old Sep 29, 2012 | 11:13 AM
NukeC5's Avatar
NukeC5
Beat me to it, good work
Old Sep 29, 2012 | 11:37 AM
dadaroo's Avatar
dadaroo
Looks like a tight area. It helps when removing a bad hose to carefully cut it with a razor blade/box cutter knife to reduce the stress on connections when removing. A little oil or something similar (slippery) on the replacement hose ID and connectore OD will make installation easy(er).
Old Sep 29, 2012 | 11:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT pictures!! Good find and YES,, I too save money where I can.
Do you mind if I save and use that picture so I can point someone else in the future to that very same vacuum leak?
OH,, By the way,, this is a very common issue.
BILL
Old Sep 29, 2012 | 02:05 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
That wire was actually intended to be a heat sink, for the PCV valve and it's rubber boot.
To A little help
