Reduced Engine Power
Old Oct 1, 2012 | 09:49 AM
Lucky Larry's Avatar
Lucky Larry
8th Gear
Default Reduced Engine Power
I have an 01 Vette I bought new and had it heavily modified. Its been this way for a number of years. and ran great for quite awhile, and still does when it does not fall into reduced engine power. I "think" this is caused by
some traction control sensor, but I need to find someone who can fix the problem. It has done this for a long time and at times I could eliminate it by shutting it off and restarting, but its gotten worse. I also need to eliminate the low tire pressure warning or have sensors re-installed in the wheels.
Any help pointing me to someone who can figure this out would be greatly appreciated.
Old Oct 1, 2012 | 09:50 AM
1986coupe's Avatar
1986coupe
What codes are you getting?
Old Oct 1, 2012 | 09:52 AM
cdkcorvette7's Avatar
cdkcorvette7
Pull and post your DTC's per the instructions below. Everyone will just be guessing without them...
Also, what do you mean by heavily modified? What all is done?
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
LiteraCola's Avatar
LiteraCola
It will be easier for us to help you out if we know what DTCs are showing up. Once you get them, post them on here and someone will be able to help out!
**EDIT** Dangit someone beat me to it.
Old Oct 1, 2012 | 12:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Traction control issues will not cause your issues. Its a throttle by wire issue or a total air flow mis match from the MAF.
I agree,, the DTCs will help diagnosis the issue.
BC
Old Oct 1, 2012 | 10:08 PM
chevy406's Avatar
chevy406
Most likely this will have to be corrected in your tune. Can be caused by larger cubic inches, different MAF calibrations, larger throttle body, etc.
Engine Diagnostics > General > Calculated Airflow vs TPS vs RPM - P1514 error
this table will need to be adjusted to match your current engine airflow...
Tire Pressure Sensor activity can not be turned off or modified by HP Tuners or EFI Live.
Old Oct 1, 2012 | 10:39 PM
robert miller's Avatar
robert miller
BC
Need to get a good tuner to look at the car... In your VE table... Robert
To Reduced Engine Power
