After Sitting, Rough Idle.......
Old Oct 2, 2012 | 11:17 AM
ZimC6's Avatar
ZimC6
Default After Sitting, Rough Idle.......
I did some searching and haven't come up with any help.
If my 2001 Stock C5, manual, 28K miles, may sit for several weeks....
It starts up OK, but will then idle very rough for a bit, stumbles, eventually clears up and runs well after that. This has happened several times.
I would appreciate any help.
Oh ya.........no codes..........
Old Oct 2, 2012 | 01:25 PM
3boystoys's Avatar
3boystoys
Check your fuel pressure.
Old Oct 2, 2012 | 05:28 PM
Tron Z's Avatar
Tron Z
1st - How long is a bit?
2nd - Any smoke out the tailpipe when this occurs? If so, what color?
3rd - Please confirm that the symptom does not also occur after sitting overnight. If the problem also happens overnight, are you loosing coolant? BTW - It only takes a few drops to cause this.
Old Oct 3, 2012 | 07:10 AM
ZimC6's Avatar
ZimC6
Maybe 15-20 seconds.
Need to get it to happen again to check for tailpipe smoke.
Doesn't happen overnight.
Didn't notice any coolant loss.
Thanks for the help guys!
Old Oct 3, 2012 | 10:01 AM
3boystoys's Avatar
3boystoys
A leaky injector will do this. When you shut the car off, the injectors should SHUT CLOSED not allowing the pressure in the fuel system to leak into the cylinders after you shut the car off. If you have a leaker, the car will be flooded on startup causing the rough idle till the car burns off the excess. That's why checking the fuel pressure (especially AFTER the car is off) will tell you if you have a leak. The pressure in the fuel rail should hold for quite some time after shutoff.
Old Oct 3, 2012 | 10:16 AM
ZimC6's Avatar
ZimC6
Thanks, I was thinking it seemed like it was "loading up"
I'll check that out.
But then how do you determine which one?
Appreciate the help!
Old Oct 3, 2012 | 03:18 PM
3boystoys's Avatar
3boystoys
Removing the plugs generally can tell you, the really black one(s) or wet one(s) are usually the culprit. Are you getting any P030X codes in the DIC when it happens?
Old Oct 3, 2012 | 09:25 PM
ZimC6's Avatar
ZimC6
No codes.....
Old Oct 4, 2012 | 05:33 PM
Tron Z's Avatar
Tron Z
Yes, the fuel rail should maintain pressure after the engine is shut down. This is to prevent vapor lock issues on a hot restart. If the pressure drops rapidly, this would indicate a leaking injector, or a leaking check valve in the fuel pump (assuming your fuel lines are in good shape).
The best way to determine which injector: pull the injectors/fuel rail assy. out of the intake and then manually run the fuel pump for a second. The problem injector should be obvious.
*** This diag can potentially be dangerous! Do not do this with a hot engine!! Use common sense!!! If this is outside of your comfort zone, don't hesitate to take the car to a competent tech. I will not be responsible if you burn your house down!!!! ***
If all of the injectors are leak free, but the fuel pressure still drops, this would suggest the check valve, by the process of elimination.
The fuel rail should maintain pressure for several hours at a minimum. It probably will not hold pressure for days, or weeks. With no pressure in the rail, the engine will act as you describe, until the pressure builds back up and any air is forced out.
Old Oct 5, 2012 | 06:52 AM
ZimC6's Avatar
ZimC6
Awesome post! Thanks for the help.
Zim
To After Sitting, Rough Idle.......
