Engine Build Question
Old Oct 8, 2012 | 05:04 AM
deniedkthx's Avatar
deniedkthx
Default Engine Build Question
I'm not much of a numbers guy... but maybe some of you out there are...
Roughly how much horsepower would a LS6 347 Stroker make with
243 Heads
.625 beehive race springs
7.450 pushrods
230-236 / 591 - 601 / 115 Comp cam
at 11:1 ??
Old Oct 8, 2012 | 11:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
410- 420 rwhp. 380-400 rwtq
bc
Old Oct 8, 2012 | 12:15 PM
NukeC5's Avatar
NukeC5
Someone on here just stated that they made 440whp with a slightly weaker cam (228/230 ish) and stock displacement. With ported 243 heads and your specs, my guess would be around 440-450whp.
Old Oct 8, 2012 | 12:26 PM
deniedkthx's Avatar
deniedkthx
Thanks guys, My estimate was around 500... maybe I was shootin for the stars lol
Old Oct 8, 2012 | 01:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I didn't notice that you said STOKER... Whats it stroked to? 402? If so, then easily 450.
I strongly recommend getting a FAST 92 or 102.. That will make a big difference. I have similar mods on my 02 Z with a home ported fast 90 and I easily achieved 450 RWHP
Old Oct 8, 2012 | 01:15 PM
deniedkthx's Avatar
deniedkthx
Well, I'm not sure yet... I'm looking at the block...
The guy said it may be a 427?? But I have no way of telling or... can anyone help me out?
Aside from ripping the block apart... any other ways to tell what the bore and stroke is? like piston size?
Old Oct 8, 2012 | 02:59 PM
Lothar34's Avatar
Lothar34
You just said it was a 347 though? 347 is usually just a 346 bored .005" and left with the regular 3.622" crank.
Old Oct 8, 2012 | 03:06 PM
deniedkthx's Avatar
deniedkthx
I took a guess at the 347... being that it's an LS6 block?
Old Oct 8, 2012 | 03:11 PM
NukeC5's Avatar
NukeC5
He just mean that it is a stock block with a stroker crank.
Old Oct 8, 2012 | 03:13 PM
lucky131969's Avatar
lucky131969
Neither makes sense. Stock is 346, and stroked cannot be a 347.....
Old Oct 8, 2012 | 03:16 PM
deniedkthx's Avatar
deniedkthx
My fault then.. I don't know much about the LS6 I thought the stock LS6 was a 347.
Old Oct 8, 2012 | 03:17 PM
NukeC5's Avatar
NukeC5
It made sense to me, he was just confused on the numbers. What else would it be?
Old Oct 8, 2012 | 03:24 PM
deniedkthx's Avatar
deniedkthx
Yeah, just confusion on my part.. Basically this thing was dyno'd with 600 hp.. I know its an LS6, I can see the 243 heads... But unsure as to the stroker to achieve 600 hp
Old Oct 8, 2012 | 03:32 PM
NukeC5's Avatar
NukeC5
Many, many people put 243 heads on as a modification. So it does not necessarily make it an LS6. If you had a Z06 it would be a no brainer, but most likely it is a stroked LS1 with 243 heads.
So it has already been dynoed at 600? I dont get what the question is then...
Old Oct 8, 2012 | 03:34 PM
deniedkthx's Avatar
deniedkthx
Yeah, it came out of a 2003 Z06...
dyno'd at 600, my question what kind of bore and stroke done to an LS6 would reach this?? cause no way is it still a 346
Old Oct 8, 2012 | 03:43 PM
NukeC5's Avatar
NukeC5
No it is not a 346. It can be considered stroked with a different crank to make it a 402 or possibly larger. No bore modifications are needed. I don't know what bore it would have to be to make that power. There are many factors like the cam, compression ratio, and intake/ exhaust components. Every engine is different and some put out surprising numbers and others not so much.
Now did the car come with a dyno sheet or where you told these power numbers? A stroked and cammed engine with your specs is usually around 450whp. I must say that I do not believe it can be anywhere near 600 without nitrous or forced induction.
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You were either lied to, they made a mistake quoting the HP or you have a VERY UNIQUE/EXPENSIVE and RARE engine.
You normaly only see 600+ HP thru Forced Induction.
To Engine Build Question
NukeC5's Avatar
NukeC5
Barely beat you to it, but my thoughts exactly
Old Oct 8, 2012 | 03:45 PM
deniedkthx's Avatar
deniedkthx
Yeah, well he claims that, (like my vette) it's a C5R block but im not exactly sure what to look at
Old Oct 8, 2012 | 04:39 PM
lucky131969
It can be considered stroked with a different crank to make it a 402 or possibly larger..
You're thinking of an LS2, which is a 364 cid (3.63 inch stroke), and using a 4 inch stroke will yield a 402.
