no communication on DTC
Old Oct 17, 2012 | 07:58 PM
Al Jed's Avatar
Al Jed
everything still says no comm
EXCEPT
60 IPC now it lists 7 codes
U1255H
U1064H
U1160H
U1056H
U1088H
U1040H
U1176H
any ideas
also
thanks for you help
Al
Old Oct 17, 2012 | 09:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good,, That tells me that the IPC is reporting that everything else is NOT reporting.
Disconnect all the wires from the STAR connectors and use an OHM Meter and read each module /wire to ground and see if one is shorted or very LOW resistance.
Bill
Old Oct 17, 2012 | 10:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Write down all the readongs that you get and post them
Old Oct 19, 2012 | 06:25 PM
Al Jed's Avatar
Al Jed
OK here we go
LH door 10.84k
RH door 10.84K
LH seat 10.69K
HVAC 149.7K
Inflatable restraint 10.71K
BCM 31.4K
ESC 4.93M
PCM 1.577K
Radio 10.75K
Remote control door lock 11.3K
IPC 144K
Old Oct 20, 2012 | 07:48 AM
Al Jed's Avatar
Al Jed
sorry
that is 143.8K
Old Oct 21, 2012 | 06:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
1.5K looks very low for the PCM... I will have to go out and read mine and compare readings.
BC
Old Oct 22, 2012 | 08:01 AM
Al Jed's Avatar
Al Jed
thanks
Old Oct 24, 2012 | 07:32 AM
Al Jed's Avatar
Al Jed
Bill
have you had a chance to check?
Old Oct 24, 2012 | 08:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I "JUST" got back from a business trip and was informed that I may have to do another one out of country. I will try to get the readings before I leave.
Bill
Old Oct 24, 2012 | 08:16 PM
Al Jed's Avatar
Al Jed
much appreciated
Old Nov 7, 2012 | 03:52 PM
Al Jed's Avatar
Al Jed
Hope everyone is OK after Sandy
has anyone had a chance to check
resistance on PCM
Old Nov 28, 2012 | 08:37 PM
Al Jed's Avatar
Al Jed
Bill
are you still out there
please advise
thanks
Al
