no communication on DTC
Old Oct 8, 2012 | 04:55 PM
Al Jed's Avatar
Al Jed
Default no communication on DTC
My 03 sat for several months ( indoors ) and now i have a host of trouble
1) shocks inoperative
reduced engine power
low fuel
check tire pressure
service vehicle soon
service ride control
service tire monitoring system
2) every module in DTC says NO COMM
3) car starts and seem fine but driver controls will not operate passenger window, lock or mirror
4) I checked all grounds and door connections there is no corrosion
car only has 7000 miles and is garaged
PLEASE HELP
Old Oct 8, 2012 | 05:52 PM
n8dogg's Avatar
n8dogg
I wouldn't rule out the grounds. I have seen cars with similar conditions and it's always a ground. I would disconnect the battery, remove the grounds in the engine bay... should be three... 2 on frame just in front of the shocks and one next to he battery tray. Use a wire brush to strip the paint down to bare metal. Wire brush all terminals. Install a star washer to bite into the frame, them the terminals, then another star washer and last the nut. After all is clean and secure, spray some battery post anti-corrosion coating on the grounds.
If that doesn't solve your problem it could be a bad Star Connector or BCM.
Old Oct 8, 2012 | 06:04 PM
lucky131969's Avatar
lucky131969
low fuel
check tire pressure
PLEASE HELP
Before you go on a wild goose chase checking/cleaning grounds....know this.....some systems HAVE to be communicating. Namely, the BCM and PCM. Why ? .... because it starts and runs.
I will PM you info on what to check next.
Old Oct 8, 2012 | 07:25 PM
n8dogg's Avatar
n8dogg
There are multiple threads on here for this exact condition. The ground seems to be the culprit, mainly the one next to the battery.
The key is the service shocks message... a lot of times the cars that show this don't even have selective ride.
Old Oct 8, 2012 | 07:31 PM
lucky131969
Ok, I'm not very good with this electrical stuff.
Old Oct 10, 2012 | 03:43 PM
Al Jed's Avatar
Al Jed
I have checked grounds and are perfect No corrosion very clean
even thought there are several threads they are not like this I have no codes just NO COMM and passenger door cannot be controled from drivers door
Old Oct 10, 2012 | 04:24 PM
Dennis Wilson's Avatar
Dennis Wilson
Try pulling the accordian connectors between door and body (Driver side first) Pull the wires out of the body side, there are two connectors . take them apart, clean tham, I used WD 40, plug them back together . Mine were corroded, especially the black one, Had exact same symptoms you describe.Been good for a year now! Check out Bill Curlee elec. posts. There are pics of the connectors and how you remove the accordian boots.
Old Oct 10, 2012 | 05:00 PM
n8dogg's Avatar
n8dogg
You're missing the point... Re-read my post.
There will be no corrosion. The frame and grounds are painted. Paint reduces or eliminates conductivity. With engine vibration, I imagine the grounds, terminals, nuts, etc... can shift ever so slightly. It's possible that there is just not good contact. With the composite body panels, ground connections are even more vital than other vehicles.
Do your self a favor disconnect the battery and wire brush that ground and all the terminals to it. See if it makes a difference or not.
IF... that doesn't do the trick, disconnect the battery, then remove the BCM for one hour. The BCM will hard reset. Reinstall BCM, connect battery and see what you got.
This is all coming from a guy with YEARS of experience of working on strictly Corvettes. I am not telling you all of this for laughs.
Old Oct 12, 2012 | 05:14 PM
Al Jed's Avatar
Al Jed
verified battery 100% charge and perfect on load test
all connections are perfect???
removed BCM and reinstalled after 1-2 hours
I have now cleaned grounds for a third time
NO CHANGE AT ALL
what now
any ideas
Old Oct 12, 2012 | 05:27 PM
Dennis Wilson
Did you try # 7?
Old Oct 12, 2012 | 05:32 PM
Al Jed's Avatar
Al Jed
tried that already
Old Oct 12, 2012 | 06:32 PM
n8dogg's Avatar
n8dogg
NO CHANGE AT ALL
what now
any ideas
Did you actually wire brush the grounds and use the star washers?
Did you take a look at the grounds at the bottom of both A pillars?
What are the current DTCs? Please list them.
Have you tried removing the star connectors and reinstalling them? They are located next to the BCM in the harness.
Old Oct 12, 2012 | 06:43 PM
lucky131969
Whoever told you that actually works......needs a "hard reset"......
Old Oct 12, 2012 | 11:35 PM
sunchaser73's Avatar
sunchaser73
Ha!
I don't know what advice lucky has given, but I would follow it...and not give much thought to what other "experts" have told you. Think about it...
Hope you get this problem solved...I know electrical issues are a headache!
Old Oct 13, 2012 | 09:12 AM
n8dogg's Avatar
n8dogg
Corvette's Of Houston indicates this is what occurs when you disconnect the BCM in their instructions of their CLB. I don't see you offering much information, so maybe a static reset is a simple thing to perform that is worth a try before taking the car in to a mechanic... considering the BCM is the main communicator between modules.
Through personal experience diagnosing and repairing Corvettes for this exact same condition, one was fixed by wire brushing and treating the grounds, another was fixed by replacing the star connector and the last was fixed by replacing the BCM.
If you knew someone with a similar car you could try their BCM and see if the codes go away. You will need to have the BCM reprogrammed if you end up replacing it for good, but for testing purposes you can just turn the key on and see if the messages go away.
Old Oct 13, 2012 | 12:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PLAIN AND SIMPLE,,,,,,,,,,,,,,,,,,,,,,, The absolute easiest thing to do is the accordion tube check. ITS FREE,, TAKES 1 minute...
Open both doors, shake the hell out of the accordion tubes. If the COMMS return, let us know for the fix.
BC
Old Oct 15, 2012 | 07:47 PM
Al Jed's Avatar
Al Jed
I shook the hell out of them
No Change
any other ideas would be appreciated
To no communication on DTC
Old Oct 15, 2012 | 08:33 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
I would read this thread VERY carefully :
http://forums.corvetteforum.com/c5-t...-there-is.html
Shaking the accordion tube doesn't always change/improve the symptoms.
Yeah,,, its a QUICK test/check.... Your best bet is to disconnect the STAR Buss connector that has FOUR wires to isolate the DOORS and SEAT Module.. If that fixes it, one of the modules is the issue and you will need to track it down
Old Oct 16, 2012 | 07:47 PM
Al Jed's Avatar
Al Jed
NO CHANGE
all still the same
Old Oct 16, 2012 | 08:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ok,,,, DO THIS. Disconnect BOTH caps. Use some jumper wire and carefully connect "JUST" the BCM. PCM and IPC toghether. See if you regain normal IPC functions.
That will eliminate all other modules from the problem.
Bill
