Another Yella Terra failure (round 2)
My rockers have the stamp to the left of the pushrod cup. They were produced in 2009, I would say somewhere around the early part of that year as I got them in Sept 09.
This shows the added material on the newer rockers. This is mine, and it is hard to tell, but it "appears" that mine have slightly less radius than the newer ones. I will try to varify the measurement off my old ones when I can.
So at this point, I am just waiting for my Bore Scope to be returned so I can go fishing for a piece of aluminum from the broken rocker. If I can not find it, the heads are going to have to come off, possibly the engine if I have to pull the whole pan. After all of that, and I get the engine put back together, I can remeasure for new pushrods again.
Can you see any evidence of the push rod coming into contact with the insert?
So for now, I think I will be putting a stock ls6 cam in my stock ls6 that is sitting in the corner of the garage, and putting that back into the car. I will still plan on putting a transmission brace in, fixing my torque tube, and putting my big A$$ fuel system in, but just not the engine or turbo setup. I will hold on to the LS2 thats coming out for that build late next year.
On the press fit on the YT rockers for the pushrod cup, I never really had a problem with the cup, just the strap of aluminum that holds the rocker body to the trunion. Thats where my failures start, and the crack just runs up the body.
I hate to hear that YT hasnt helped in any way ROB@CHAMPIONMOTORS, they have been very quick and easy each time I had an issue. Heck, I think they keep tabs on my threads lol! The guy I have been dealing with, Jim Petrakis, has been pretty cool and we even have shot the bull via email a few times on my build.
After all of this, I still dont have any bad beef with YT, and I will still use their rockers, just not in an as aggressive cam setup.
Second car was a C5 with a 402 procharger F1 supercharger with AFR225 heads, patriot golds, and HYD roller cam 239/247 624/624 on a 113
Car ran for less than a few hundred miles before rocker push rod cups started to wear excessively.
Called Yella Terra USA said warranty guy was away called back next month,called again said he is not in,called 5 more times said leave a message no return call. Emailed Yella Terra Austrailia twice no reply. Hinson called us to buy rockers, told him story said he would see what they could do haven't heard back from them in months.
On my 02 Z06 TTIX with AFR 245 heads I am running stock rockers with Zinc additive. Tried new comp 1.72 gold rockers had dyno graph nose dive above 5500rpm, to heavy on the nose. Want to use Yella Terras, but afraid they will break on my combo also.
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
I spoke with Shawn this week. He has a set of the Crane prototypes and he said they look really nice. He should have a set of production units for my car soon. As usual, these things take much more time than you hope. I'm actually reluctant to drive my car hard while the YT's are still in there after breaking a couple from two different sets.
Don't forget to post a picture of those RR...as well as the specs fpr the 1.7 ratio, and their weight over the nose!!!
Christian
Hoping it's something simple!
