Ever seen a spark plug look like this?
Old Oct 11, 2012 | 02:57 AM
steven31371's Avatar
steven31371
Default Ever seen a spark plug look like this?
every one of them look like that....besides the fouling, look at that gap!
its more than double the largest 45 gap that my gap measurer goes to...must be well over a 90 gap....
and the spark plugs wires are disentigrating in my hands
this seems crazy to me, and frankly I am a little embarrased that I have had the car for three months now and not checked this sooner...have changed the oil twice, done lots of mods, changed bushing, flushed and changed all fluids etc...but for some reason just never got around to checking the plugs....I really am embarrased
has any one ever seen a gap set that big on a plug in a C5 before?
wonder why they would have done that.
I tracked down the previous owner and he was an older guy that owned it from new and took emaculate care of it....but this spark plug thing is crazy to me....whats even more crazy is that the car seems to have been running tip top with those plugs like that...
Old Oct 11, 2012 | 04:36 AM
vettenuts's Avatar
vettenuts
I just changed the plugs in by daughter's Jeep this past week. Plugs looked the same, but had 117K miles on them. Funny thing is the car ran fine, I changed them more from guilt than anything else. The wires aren't a surprise. They are awful to remove and many guys break them in the process. I went with new GM LS7 wires, with the 90 degree spark plug end on them.
Old Oct 11, 2012 | 05:48 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
How many miles are on the car?
Old Oct 11, 2012 | 06:02 AM
Cybermind's Avatar
Cybermind
They just look very old to me. Nothing out of the ordinary. The wide gap tells me that they should have been changed a long time ago.
Old Oct 11, 2012 | 07:32 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Oct 11, 2012 | 07:45 AM
lucky131969's Avatar
lucky131969
This should serve as a wake up call that you need to go through everything i.e. change tranny and differential fluid, flush coolant, brake fluid, etc.
Old Oct 11, 2012 | 10:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The secondary ignition in the LS series engines are built very well and will continue to work under the worst of conditions.
That goes to show you that you DO NOT need any aftermarket mods in that area. If you have not already done so, get a new set of AC DELCO Irridum plugs and a set of GM Performance Red wires and you will be set for a LONG TIME!
Old Oct 11, 2012 | 10:32 AM
ssrallyred's Avatar
ssrallyred
Used to se that shade of color on cars that ran octane boosters all the time. Not sure if techron etc. can cause that or not.
Old Oct 11, 2012 | 11:00 AM
steven31371
lol...good call, I use Nitrous Express or NOS Octane booster in my last several tanks
Old Oct 11, 2012 | 11:10 AM
steven31371
yeah, I'm amazed that the coils could push an apparently good spark through those plugs.
I spent several days researching plugs because I installed a Nitrous kit and wanted to put in a good colder plug...ended up going with a none projected tip NGK plug that works best for Nitrous applications.
I got two sets to try out. One set with seven plugs that are one heat range colder with a single plug that is two heat ranges colder for the hotter running 7th cylinder....and the second set is two heat ranges colder with a single plug that is three heat ranges colder in the 7th cylinder.
will gap all plugs at 35.
she's my daily driver and the wires shredded, so I have to pick up whatever plug wires auto-zone has in stock, but will order some race rated plug wires that can handle sustained high heat and put some socks over those too.
Old Oct 11, 2012 | 11:14 AM
steven31371
haha, mine has a bit over 117k mile too, I bet those plugs were never changed, it ran really well and didn't seem like it wasn't making a good spark.
Old Oct 11, 2012 | 11:19 AM
n8dogg's Avatar
n8dogg
Doesn't look too abnormal, the wire may have been your doing when pulling it out. Good time to replace them though.
Old Oct 11, 2012 | 11:20 AM
chris04gto's Avatar
chris04gto
Yeah mine, last week I just changed the plugs and wires on my newly acquired Vette and the wires just crumbled. The plugs looked essentially like yours do.
Old Oct 11, 2012 | 12:43 PM
lionelhutz's Avatar
lionelhutz
I think there was a platinum tip or "puck" on the ground electrode of the stock plugs that tended to fall off and losing that "puck" would open the gap a fair bit.
To Ever seen a spark plug look like this?
