solution to ABS traction system problem
Old Oct 25, 2012 | 11:49 AM
mikeyboy1's Avatar
mikeyboy1
Default solution to ABS traction system problem
Hi all. I have a 1998 convertible that I had diagnosed that my EBCM and both front wheel wire harnesses to it were bad. This was from John L Sullivan Chevy in Roseville Ca. They told me the ECBM was no longer available anywhere, including aftermarket, basically rendering my vette unsellable and worthless. I thought I would fix it myself, but couldn't get the ECBM off. I sprayed DW40 on both ECBM connectors before plugging it back in. My ABS brakes now work perfectly after being down for over 2 years. What a miracle that DW40 fixed it and the dealer was totally wrong. I wonder how many of you went through the same thing, only to put out money that was unnessesary?
Old Oct 25, 2012 | 12:00 PM
lucky131969's Avatar
lucky131969
It certainly pays to own a service manual, meter, and learn how to troubleshoot problems yourself.
Old Oct 26, 2012 | 09:55 AM
johnson-rod's Avatar
johnson-rod
Gezz. Dealer advice that was wrong. That's never happened before....
Old Oct 26, 2012 | 10:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Everyone says and spells it wrong.. Its STEALERSHIP
I bet they offered to take it off your hands for a record LOW offer!!!!
BC
Old Oct 26, 2012 | 10:16 AM
3boystoys's Avatar
3boystoys
I'm really surprised dealers get any after warantee work at all.
Old Oct 27, 2012 | 12:29 AM
andrec10's Avatar
andrec10
They AINT ever touchin my Vette!
Old Oct 28, 2012 | 03:59 PM
mikeyboy1's Avatar
mikeyboy1
Since the DW40 worked for 1 week before the Abs light came back on, I figured it's got to be a connection problem so I'm going to put some "conductive grease" in the connectors and see what happens. I'll let you all know the outcome.
Old Oct 28, 2012 | 04:25 PM
johnson-rod
Just for fun, switch the front wheels' ABS wires from side to side and see if your problem goes away.
Old Oct 28, 2012 | 06:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
"conductive grease" is not recommended and could make things worse!
BC
Old Oct 29, 2012 | 12:48 AM
mikeyboy1's Avatar
mikeyboy1
Default conductive grease.
BC
At this point, I don't think it could get much worse. Why do you think the grease would be bad?
Old Oct 29, 2012 | 01:34 AM
IRON MAIDEN's Avatar
IRON MAIDEN
subscibed. I get the damn warning off and on as well. I can actually feel a difference in my power steering, many times I notice it before the light even come on my dash. I've been wanting to clean all the grounds and see if it fixes it. Forget all the glound plug locations and proper way to clean them.
Old Oct 29, 2012 | 07:33 AM
runner140*'s Avatar
runner140*
I went to a dealership, for an oil change, eight years ago, and that was the last time. The oil change was close to $100.00 and it took all day.
Dealerships force us to do all our own work. I like it that way.
Old Oct 29, 2012 | 08:34 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have a poor connection, putting grease between the contacts will insulate it even more. The grease is NON CONDUCTIVE not conductive. If it were conductive, it would short everything out.
Old Oct 29, 2012 | 10:01 AM
mikeyboy1's Avatar
mikeyboy1
It's silver conductive grease. I'm only using it on the female connector and will make sure not to have any excess on the outside. I'll let you all know how it goes.
Old Oct 29, 2012 | 07:13 PM
grillsja's Avatar
grillsja
Go here:
http://forums.corvetteforum.com/c5-t...c-c1243-h.html
Old Oct 29, 2012 | 07:16 PM
grillsja's Avatar
grillsja
Then go here:
Priceless info thanks to pewter99
http://forums.corvetteforum.com/c5-t...ould-have.html
Old Oct 29, 2012 | 07:23 PM
grillsja's Avatar
grillsja
Originally Posted by grillsja
Then go here:
Whoops...I meant here:
http://forums.corvetteforum.com/c5-t...l-in-here.html
Last edited by grillsja; Oct 29, 2012 at 07:29 PM. Reason: credited wrong person in quote
To solution to ABS traction system problem
Old Oct 29, 2012 | 11:59 PM
lionelhutz's Avatar
lionelhutz
Take a look at the connectors. There might be a damaged female pin or 2 that needs to be bent a little or replaced. Fix it correctly and it won't keep acting up.
Old Nov 3, 2012 | 01:05 PM
mikeyboy1's Avatar
mikeyboy1
Well the conductive grease didn't change a thing. It's made with silver and is highly conductive. I'm disappointed.
Old Nov 3, 2012 | 01:40 PM
johnson-rod
Now that you've made a mess of it, take the connectors apart (yes they come completely apart) and clean them with electrical contact cleaner. While you have them apart you will see how to bend them correctly to make better contact. It's not obvious when they are assembled. Then reverse them right to left when you put them back on.
Good luck. Hope this helps.
