Diff Leak
Old Jun 5, 2002 | 08:03 PM
georgec114's Avatar
georgec114
Default Diff Leak
OK...Just got back from dealer where they replaced the following:
Alternator
Harmonic Balancer
Idler Pulley
Driver's side diff seal
They did a really nice job...No scratches or dings. They used a drive-on ramp but I left them my pucks just in case.
When I asked if they did a full diff fluid replacement and if they put in
the additive, the tech said "Didn't need to."
After the seal replacement, he said the diff was still full.
Can this be true? Can a left side axle be removed and cover removed and seal replaced and still no fluid leaks out?
I need help understanding this. ANYONE?
:confused: ...GeorgeC
Old Jun 5, 2002 | 10:15 PM
davidfarmer's Avatar
davidfarmer
Default Re: Diff Leak (georgec114)
It is true. They usually only leak when over-filled. They could have probably just let the extra fluid out, put the cap back on, and you never would have known the difference.
Dave
Old Jun 6, 2002 | 12:56 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
You can pull the axle and not loose fluid because the fill plug is higher than the axle seal,BUT,if you remove the side cover you will loose ALL the fluid...I would assume that they didnt remove the cover...
Old Jun 6, 2002 | 04:05 AM
Vmax's Avatar
Vmax
Recently I heard, that GM will provide a new type of seal to address the problem.
There also was a post by Jim Helm, fortunately I saved it and assuming Jim's
permission ;) ...
"I spoke to the Power Train Engineer for Corvette at the 2001 Carslile Show and
he tole me that they know there is a problem with the left seal and they should
have a new seal designed and ready for replacing the old style seal by the summer
of 2002. This probably means that it will be at the dealers no later then the end
of 2002, and may be a standard for the 2003 model year."
In the meantime, does anyone have more details or a date when available?
:cheers:
Old Jun 6, 2002 | 02:38 PM
georgec114's Avatar
georgec114
Default Re: Diff Leak (C-5 TECH)
C-5 TECH
I see that they replaced left side axle seal...Is this different from
the diff seal? The tech said was visually deformed.
...GeorgeC
Old Jun 6, 2002 | 02:59 PM
ruking1's Avatar
ruking1
You might also listen for differntial gear grinding due to possible change in the 6% of friction modifier solution also. I just recently brought mine in for a leaking differential. To diagnose they put in dye for a black light inspection. They retorqued the covers, road tested, black light inspected let it sit overnight and performed a visual and black light inspection, no trace of dye. ie no leaking
When I brought it home I noticed a grinding sound So I brought it back in and mentioned that dye can actually change the friction modifier solution. They duplicated the sound and changed out the differntial oil and friction modifier.
Old Jun 6, 2002 | 03:23 PM
georgec114's Avatar
georgec114
Default Re: Diff Leak (ruking1)
RUKING1
Thanks for the heads up...Yeah, they did a tracer dye too.
I'll most likely give it a few weeks to confrim no more leaking
and change out the fluid and additive.
...GeorgeC
Old Jun 6, 2002 | 03:28 PM
ruking1's Avatar
ruking1
I had forgot to mention that the grinding sound happened with tight slow figure 8 type turns. The dealer also covered under warranty the differntial and friction modifier change. Not even a quibble.
[Modified by ruking1, 11:29 AM 6/6/2002]
Old Jun 6, 2002 | 03:43 PM
georgec114's Avatar
georgec114
I had this with my Supras. It was amazing that between every
20-25K miles, the noise would show up.
It became a habit at every 4 oil changes, I'd do the diff change.
Toyota used the GM additive as well. It's just a little acid based
fluid to keep the internal plates/disks from sticking.
...GeorgeC
Old Mar 2, 2012 | 04:02 PM
jpulone's Avatar
jpulone
I do believe I have a tranmission leak on my C5. I have 107,000 miles on it.
I am looking for a local independent shop/mechanic to fix it.
I live in south Orange County California.
Old Mar 2, 2012 | 04:16 PM
8VETTE7's Avatar
8VETTE7
Nothing like reviving a 10 year old thread to ask for help with your problem rather than starting a new thread...............
Old Mar 2, 2012 | 04:18 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/foru...s-or-more.html
To Diff Leak
