high beam mod
Old Oct 31, 2012 | 03:46 PM
dbaker's Avatar
dbaker
Default high beam mod
Seems I remember a mod to have the low beams & high beams on at the same time.
I did a search and could'nt find it.
\db2
Carolina
Old Oct 31, 2012 | 04:35 PM
UncleFodder's Avatar
UncleFodder
Member RadioFlyer sells a harness still I believe.
http://www.shop.radioflyerinnovations.com/main.sc
Old Nov 2, 2012 | 09:13 AM
dbaker's Avatar
dbaker
Many thanks.Ordered the harness yesterday.
\db2
Carolina
Old May 20, 2015 | 05:51 PM
Zhenomansh's Avatar
Zhenomansh
3rd Gear
Default It is very simple
The easest way to turn on hi and lo beams together when hi beam is on is to connect two wires on multifunctional switch.
You need to connect thick white (middle one) and thick tan wires together.
If you loose exterior light during connecting wires - check fuse #6 at passanger feet fuse block.
Here is the diagram.
it fom '99 but it fit my 04 c5. connect tan and white wires to make lo beam works too, when hi beam is on.
To high beam mod
