Looking for a Gas Cap O-ring
Old Nov 7, 2012 | 01:35 PM
beary58's Avatar
beary58
Default Looking for a Gas Cap O-ring
Hi all
Looked through search and couldn't find a source for the o-ring. Mine is really cracked and I hate to buy a new cap just for the o-ring.
Thanks a head for any help.
Beary
Old Nov 7, 2012 | 01:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There have been several post on this very issue. I just applied black RTV to mine, covered the fller neck opening with celephane, installed the cap and let it cure. After it cured,, remove the cap, removed the celephane and BAM,,,, NO MORE LEAKS. I am still looking for the O ring specs also so that I can replace the O ring.
I,,, like you,, cant see wasting a perfectly good cap for a damn 50 cent O ring.
BC
Old Nov 7, 2012 | 04:14 PM
beary58's Avatar
beary58
BC
OK, I did read this but was hoping someone found an O-ring. I will try your RTV idea, worst that can happen is I will still need to get a new cap.
Thanks.
Beary
Old Nov 7, 2012 | 11:15 PM
Dave68's Avatar
Dave68
I'm guessing the dealership doesn't have any? If I can remove mine, I should be able to tell what size and material it is. Buna N and Nitrile are generally resistant to gasolene. Viton is a step above in terms of resistance and cost. Of course, if it's not shaped like an o-ring, then it is probably custom-designed.
Old Nov 8, 2012 | 07:37 AM
C5Natie's Avatar
C5Natie
Seems like a replacement is only $11 if you dont find an o-ring.
http://www.autozone.com/autozone/par...49_13324_5596_
Old Nov 8, 2012 | 01:04 PM
AngryTurtle's Avatar
AngryTurtle
Try a pool supply store. They have large o-rings.
Old Nov 8, 2012 | 01:36 PM
PUMP03's Avatar
PUMP03
Oldtimer
I replaced mine with the recommended GM cap. The replacement had a seal that is not shapped like an o-ring (rectangular cross section and molded on). I tried to remiove the o-ring shapped seal from the old cap and could not get it off without tearing/destroying it. It appeared to be molded on. From my experience I suspect it is not a standard o-ring.
Old Nov 8, 2012 | 01:48 PM
beary58's Avatar
beary58
Thanks.
Beary
Well I put a little, very little RTV on the main crack and it's working so far.
I think I'm going to treat my all my gas caps with 303 Protectant from now on.
Beary
To Looking for a Gas Cap O-ring
