1-rib--3-rib.. Differential difference?
Old Nov 8, 2012 | 10:39 AM
Juhatee's Avatar
Juhatee
Default 1-rib--3-rib.. Differential difference?
What is the difference of 1-rib and 3-rib differentials in C5? My 3.42:1 diff broke and I'm looking for a new one. I came across this rib-thing and I'm unsure if it matters in this case.
Old Nov 8, 2012 | 11:33 AM
corvettebob1's Avatar
corvettebob1
The 3 rib case is stronger due to added stiffness from the added ribs.
If you have a 6 speed hold out for the 3 rib case, if you have the A4 it's not such a big deal.
Old Nov 8, 2012 | 03:33 PM
Juhatee's Avatar
Juhatee
Thanks!
Is that 3-rib a year specific thing? I have a 6-spd and Maggie with 650 lbft torque.
Old Nov 8, 2012 | 03:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check this out!! You might want to take a look at the following two Differential UP GRADE post. That much power,, you need all the help you can get. You already have the DIFF removed:
Nice at home doable upgrade that will not break the bank:
I got ALL my C6 ZO6 parts from Gene Culley www.gmpartshouse.com
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Nov 9, 2012 | 08:55 AM
CactusCat's Avatar
CactusCat
Hope this question relates to this thread as well. Definitely NOT trying to hi-jack this thread. How much HP can the stock differential handle safely? For example, can the stock A4 differential handle 400-500 rwhp safely without too many mods? How about the M6 differential? Can the 3 rib handle more HP than the 1 rib? Thanks gents!
Old Nov 9, 2012 | 09:51 AM
NukeC5's Avatar
NukeC5
The 3 rib is a stronger case. Everything inside is the same. Except for the Z06 3-rib diff which says "SP" on the 3.42 badge. This is for the shot-peened or micro-polished gears they have.
The diffs are year specific. Early vetts got a single rib. Later got the three rib. Cant remember the exact year that the change over occurred.
An automatic is much easier on the drive train than a manual. But upwards of 500 whp and you are able to see problems. A manual needs some work at around 400whp.
For the OP, I would definitely order a stage 2 diff from RPM, RKT, or DTE. Since you have a 3-rib, they will build you a 3-rib and take yours as a core ($750). You are going to destroy another stock diff behind all that power. The stage 2 is good for 600ish whp with many parts even tested to 900whp, (like the C6 output shafts).
I ordered a stage 2 from RPM for my A4 3200 stall and Heads and cam build. Car may see 500-600 as an end goal. I shouldn't have to worry about outgrowing the diff.
Old Nov 9, 2012 | 10:33 AM
RonSSNova's Avatar
RonSSNova
I believe 01 and later 3.42 were all 3 rib.
Mine came from an 01 6 spd coupe.
I rolled my own with the 4340 shafts and C6 clutches etc. It wasn't cheap, but I don't have to worry.
I'm calling it the RJS stage 2.3
Ron
Old Jul 24, 2013 | 06:50 AM
ZR11AB's Avatar
ZR11AB
02 later? 01 some? I have 01 z06 1-rib per seller, sound right???? anyone have/can post the 1 rib 3 rib difference???
Old Jul 24, 2013 | 07:56 AM
ZR11AB's Avatar
ZR11AB
Found pics post in another thread thanks
Old Jul 24, 2013 | 03:21 PM
PRE-Z06's Avatar
PRE-Z06
'01+ all have 3-rib as far as I have seen. It's easy to visually see the difference on the top of the diff, there is either a single rib or 3.
This is a 3-rib...
http://www.ebay.com/itm/97-04-Corvette-C5-GETRAG-Rear-Differential-3-15-Ratio-/140754604081?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c5a0d031&vxp=mtrThis is a single rib...
http://www.ebay.com/itm/97-04-Corvette-C5-Rear-Differential-3-42-Gear-GETRAG-Used-OEM-GM-/290947564351?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bdd3833f&vxp=mtr
To 1-rib--3-rib.. Differential difference?
