DIC control
Old Nov 15, 2012 | 05:56 PM
vin's Avatar
vin
5th Gear
Default DIC control
hi everyone
i have a problem with my c5 corvette which is the button of DIC control are not working
if anyone had this problem a he fixed somehow please till me
thanks
Old Nov 16, 2012 | 09:06 AM
vin's Avatar
vin
5th Gear
what does it mean ?
Old Nov 16, 2012 | 09:36 AM
maxx2200's Avatar
maxx2200
Originally Posted by vin
hi everyone
thanks
I did a search and came up with this.
http://forums.corvetteforum.com/c5-t...operative.html
Maybe it will help. If not, do a search, there is a lot more.
Good luck!
Old Nov 16, 2012 | 09:55 AM
vin's Avatar
vin
5th Gear
it's corvette 2001 and stoke
i have changed front pumper and rear fender
Old Nov 16, 2012 | 11:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have real time dampening F-45 OR F-55 suspension. Something is defective and it is NOT working. You need to follow this procedure and read and post your Diagnostic Trouble Codes (DTCs)
Read and POST your DTCs
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Nov 16, 2012 | 11:45 AM
65GGvert's Avatar
65GGvert
If I understood correctly, he can't pull codes because the DIC buttons aren't working. I don't know what "stoke" and "pumper" mean though. Maybe someone replaced the shocks and did not delete or fool the F45 option?
Old Nov 16, 2012 | 11:56 AM
sunchaser73's Avatar
sunchaser73
I think "stoke" means "stock" and a "pumper" is a "bumper."
From what I read, he can't pull codes because some unspecified number of DIC buttons are not functioning. Until that gets resolved, he will need to find someone with a Tech2.
As others have suggested, start by checking over the mechanical condition of the shocks (leaks, etc) and the electrical connectors. Wouldn't hurt to check the ground wire for the RTD system, but I would suspect there would be other problems if it was a ground-related issue.
Old Nov 16, 2012 | 12:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The RTD Fuses are also known for blowing. Check those.
BC
Old Nov 16, 2012 | 03:52 PM
vin's Avatar
vin
5th Gear
yeah you are 100 % correct ,i had changed the shocks
how can i delete or fool the F45 ?
Old Nov 16, 2012 | 04:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need a GM TECH 2 to interface with the BCM or find someone that has one:
- C5, Disable the F45 option using Tech2 VODA1, http://forums.corvetteforum.com/c5-t...ing-tech2.html
- C5, dquagliaroli , Deprogramming F-55: http://forums.corvetteforum.com/c5-t...uspension.html
Old Nov 17, 2012 | 04:45 AM
vin's Avatar
vin
5th Gear
i just found that the guy in the workshop ,he had plug simulators
but he still gets shocks intr. in the DIC
and he can't remove the code because the DIC button are not working
Old Nov 17, 2012 | 09:53 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Fix the DIC Control issues. Theres more to SHOCKS INOP than just one thing. There are numerous electrical issues that will cause them to fail and go inop..
Take it to a shop that has a TECH2 and figure out whats throwing the DTC.
The real cure is just have them programmed out of the BCM.
BC
To DIC control
