Getting P0101 Occasionally?
Old Nov 17, 2012 | 12:09 PM
bartsky's Avatar
bartsky
Default Getting P0101 Occasionally?
Should I clean the MAF?
Old Nov 17, 2012 | 12:57 PM
87SAM's Avatar
87SAM
Sure, but more importantly check for air leaks between MAF and TB.
Old Nov 17, 2012 | 01:09 PM
bartsky's Avatar
bartsky
I will check that now, thank you...
Old Nov 17, 2012 | 03:32 PM
marvinseah's Avatar
marvinseah
Had the same problem. Turned out to be a map sensor vacuum leak.
Old Nov 17, 2012 | 09:51 PM
bartsky's Avatar
bartsky
I just went out, and looked around. There is no hose connected to tube coming from under throttle body? I guess it had throttle body bypass done. Should that tube be capped?
Old Nov 17, 2012 | 10:14 PM
bartsky's Avatar
bartsky
Where is the map sensor located?
Old Nov 17, 2012 | 10:15 PM
Marine One's Avatar
Marine One
The tube doesn't need to be capped. I capped mine just to make it look better, and only did the bypass to make throttle body removal & installation easier when cleaning it.
Old Nov 18, 2012 | 02:50 PM
bartsky's Avatar
bartsky
Did you have to remove the intake manifold?
Old Jan 23, 2013 | 10:08 AM
mike-ssi's Avatar
mike-ssi
where is the MAFS on an '04 C5 and how hard is it to clean or change?
To Getting P0101 Occasionally?
