k harness
Old Jan 18, 2013 | 03:38 PM
Jumper11's Avatar
Jumper11
Default k harness
How do I know if I have the K harness installed. GM told me I have had the recall done on my car. 2002 coupe. I want to install the clb but I have to remove the K harness first.
Old Jan 18, 2013 | 03:45 PM
3boystoys's Avatar
3boystoys
You have to take the lower part of the dash off and look for it.
Old Jan 18, 2013 | 04:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Find the small four wire connector under the steering column that the CLB plugs into and the K karness will be plugged into it. remove it and install the CLB
Old Jan 19, 2013 | 11:36 AM
Jumper11's Avatar
Jumper11
CLB instructions say remove the K harnes. That would include the relay as well? Thanks for your help.
Old Jan 19, 2013 | 04:46 PM
C5FORFUN2's Avatar
C5FORFUN2
Yes and all the info is in the stickies at the top of this page. Should find all the info you need there.
Old Jan 22, 2013 | 07:28 PM
Jumper11's Avatar
Jumper11
What is the connector with the two wire connected to? Or is these two wires (female connector) not connected to anything?
Old Jan 23, 2013 | 11:56 AM
Jumper11's Avatar
Jumper11
You're absolutely correct. I'm sorry but just wanted to know what I'm getting into before I F&^k it up. So what I'm hearing is the female connector with the two wires in it is NOT connected to anything. Just follow the wire back to the relay and then to the lock connector. I think it's easy enough. I just need to remove the LMC5R and put it back to stock before I remove the K harness (If installed) and install the CLB. Thanks you've been a great help and motivator. Gonna get it done this weekend.
To k harness
