Rocker arm rotates when torqued down
Old Nov 21, 2012 | 11:08 AM
wcsinx's Avatar
wcsinx
Originally Posted by CactusCat
If you simply tighten down all the rockers to the correct torque with the heads removed, you would not have any of these issues... correct? I do realize that the original question was dealing with the heads while they were on the motor. Also, this is not any sort of inflammatory remark..I'm simply trying to learn more and more about engine assembly and wanting a more workable knowledge... Thanks for making me think and learn.
good luck installing the pushrods with the rockers in the way
Old Nov 21, 2012 | 12:42 PM
vettenuts's Avatar
vettenuts
Originally Posted by wcsinx
If you're tightening against the valve spring, how do you know when you've got the right torque on the nut?
First, that's not what I said. Second, you will get the correct torque but the bolt preload may be low as a result. The point is, if the torque value is hit and the rocker isn't bottomed, then as soon as the load from the valve spring is removed the rocker will be loose.
Old Nov 21, 2012 | 12:44 PM
vettenuts's Avatar
vettenuts
Originally Posted by NewFoundPower
I haven't tried to start the car yet, so I'll loosen the rockers that rotated and will try to be absolutely sure that I'm on the base circle of the cam when I re-tighten them. I suppose it would be a good idea to double-check the ones that didn't rotate too so I'll do that as well before I start it. It'll be a few days before I can work on it again because of Thanksgiving but hopefully I can finish this up this weekend.
If the same thing occurs, swap one that moved for one that didn't and see if the problem follows the rocker. That isolates it to either the rocker or the aluminum saddle if there is a mechanical issue.
Old Nov 21, 2012 | 12:55 PM
wcsinx's Avatar
wcsinx
You realize that post wasn't in response to yours, right?
And I don't disagree with anything above. The point was the reason the rocker twists is because of the pressure being exerted by the pushrod. Yes, you can power through it, and get the rocker pinned down regardless while fighting against the lifter spring more than you should be. But as you said, the preload will be off.
Old Nov 21, 2012 | 01:44 PM
1999_TRC's Avatar
1999_TRC
Originally Posted by RonSSNova
I rechecked them when done. The valve springs aren't that strong. Once the rocker shaft seats on the pedestal, the spring is out of the equation.
You should really step away from this thread. You are giving poor advice. I'm no expert engine builder, but even I know not to torque down a rocker on an open valve.
Old Nov 21, 2012 | 02:56 PM
Paul 75 L82's Avatar
Paul 75 L82
Old Nov 21, 2012 | 04:45 PM
vettenuts's Avatar
vettenuts
So. Couldn't stay away.
I had wanted to check the wear pattern on the top of the valve stems after a summer of drag racing. Hadn't looked under there since first fire in June.
This post prompted me to do so.
Cyl 2 had one valve closed and one slightly open. Took the rockers off, all looked good. So w/o making sure both were on the base circle, I reassembled. On the valve that was slightly open, with the wrench set to 22 ft lbs, the bolt tightened down until it was solid on the perch. Torqued to 22 ft lbs just like it should. The valve spring offers very little resistance when opening. These are AFR 8019 springs BTW. So not whimpy. You are dealing with a ratio, so the full spring load isn't on the bolt.
Anyway, I also checked all of them when I got the valve cover off, all were fine at 22 ft lbs.
I'm not dissing the factory procedure, and I wasn't advocating trying to do this with the lifter all the way up, just saying that you don't need to be perfect on the TDC thing.
Back to the OP's issue, if he even got close as I just described, this isn't his issue.
Ron
Two things happen when you tighten against the valve spring. One, there is a risk of pulling the aluminum threads. These bolts have a lot of engagement, but in the end why risk it. Second, the bolt is preloaded less than prescribed. Torque only measures the resistance to turning, such that other factors like the valve spring force or thread lubrication can make huge differences on the final bolt preload or stretch. It is this preload that keeps the assembled joint together. A force equal to the preload will separate the joint, so as a result with less actual bolt preload it takes less load to separate the final joint. Will it separate with the method you used, maybe or maybe not but again why risk it.
Old Nov 21, 2012 | 04:50 PM
1999_TRC's Avatar
1999_TRC
Ron
So not only did you do it wrong the first time, you purposely did it wrong again. The logic used here is crazy. Now I know why Lucky left this forum.
Old Nov 21, 2012 | 07:22 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
No, the loss of oil in a lifter will not cause the rocker arm to rotate out of place when the nut is tightened. Lifters will start to bleed down the second oil pressure is gone. When you torque that nut to 22 ft-lbs, you're preloading against the spring in the lifter and not hydraulic pressure. His issue is most likely as Steve noted, in that he's trying to tighten a rocker while the lifter is riding on a cam lobe. When you try to do that, the rocker won't seat properly on that big aluminum bar/saddle because of the pressure exerted on it by the pushrod. Hence it twists out of place when the rocker nut is torqued.
So no, pretty much everything you said was incorrect and inapplicable.
Well Those are pretty stong words and a way of calling me and my experience are those of an idiot----
Basically it's just "your opinion" vs "my opinion"---
You're are saying the preload is on the lifter spring ???
The preload is the same if the engine is running or not--so you would mean that the lifter spring holds the lash while it's running as well- at 6000 RPM ??--That makes no sense---- The oil holds the "0" lash--running or not !!
The poster also doesn't provide enough information in the beginning of his post about his rocker installation procedure-He later uses other peoples suggestions to correctly find each cylinder's TDC
He says : " a few of them rotate a little bit when I get them tight"
He NEVER says : (as you somehow read) "They rotate out of place"
I've adjusted 1000's and 1000's of hydraulic lifters both roller and flat tappet---I was suggesting ( as he didn't privide an accurate description) what the most common issue is for a rocker to "jiggle" slightly after torqued or for the push rod to spin after torqued---
You can set lifter preload on adjustable type rockers (SBC/BBC) and after a few minutes most all of them will seem to loosen up-Even if you continue tightening them up---Same goes for rocker stand non adj. rockers as on a LS engine
Perhaps it's just a difference in word assignment or preception of what someone thinks he's reading----Regardless there's no excuse for saying blatantly that my "opinion" is NO or wrong----I am entitled to it--
PS: I don't agree with your's at all-it makes no sense "to me"
Old Nov 21, 2012 | 07:55 PM
wcsinx's Avatar
wcsinx
I never said you were an idiot. I said you were wrong. There is a difference you know.
Correct, contrary to popular belief lifters can be installed dry and have their preloads set just fine.
Please quote where I said the spring was responsible for maintaining 0 lash at redline. Is that how you set your rockers? At redline? The oil also provides resistance same as the spring to movement of the cup in the lifter bore. But that is not what you're tightening against when the engine is not running and there is no oil pressure.
No, you should try more reading and less assuming because that is precisely what he said. Here's where you're walking that fine line between being an illiterate idiot and just being wrong. Reread his first post. He's not talking about the pushrod spinning in the rocker cup and/or the rocker jiggling due to excessive lash. He's talking about the rocker itself rotating clockwise slightly as he tightens the nut.
Try just reading the boldfaced parts below
When torquing down my rocker arms, a few of them rotate a little bit when I get them tight and close to 22 ft*lbs, so the tip of the rocker arm is no longer centered over the tip of the valve.
Look at the pic. See how the rocker tip isn't quite centered over the valve stem. THAT'S what he's talking about. Not lash, not a spinning pushrod, and not a jiggling rocker
Old Nov 21, 2012 | 07:57 PM
lionelhutz's Avatar
lionelhutz
Wow, all these posts over something simple.
You want an easy way? Do it like this;
Exhaust valve begins to open - install intake rocker (or adjust intake valve).
Intake valve justs closed - install exhaust rocker (or adjust exhaust valve).
EOIC
Old Nov 21, 2012 | 08:06 PM
wcsinx's Avatar
wcsinx
EOIC
Brilliant!
Old Nov 21, 2012 | 11:07 PM
  #33
CactusCat's Avatar
CactusCat
"good luck installing the pushrods with the rockers in the way."
Umm.... duh.... ummm.. oops...ummm, I knew that. What can I say? It was a senior moment....
Old Nov 22, 2012 | 07:45 AM
  #34
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Paul 75 L82
This is how I did the job, back in early 2011, and had no issues.....
Old Nov 22, 2012 | 02:39 PM
  #35
tblu92's Avatar
tblu92
Not gonna argue about this anymore--But to be as bold as you---Sorry WCSINX but your interpretation is simply CRAZY!!!
And the rocker is not out of place it appears it's just a little loose from having the oil beed out most likely from the engine sitting a long time with the valvetrain out---
Why to all manufacturers tell you to "soak all new lifters in oil " overnight before installing ??? beacuse they need to fill with oil so they aren't bottomed out when you go to set the pre-load----
Old Nov 22, 2012 | 05:00 PM
  #36
wcsinx's Avatar
wcsinx
I didn't "interpret" anything. I merely told you what the OP said and showed you his picture. You accuse me of having a reading problem when it's quite obvious that you either didn't fully read or understand the first post.
Ok, NOW you're an idiot. If you think that it's ok for the rocker tip to be offset from the valve stem like that, then you need to put down the tools permanently. Have you ever assembled an engine that held together for that matter? Ponder this. Even a "loose" rocker which is to say one with excessive lash will NOT rotate side to side like that. They will "rock" up and down as per their normal range of motion but not side to side. I would like you to study these pictures very carefully.
See the big ole bearing on either side of those rockers? See how the fastener goes right through the middle of the rod those bearings (and hence the rockers) are mounted on securing it to the saddle bar? Now in order to induce a CW or CCW rotation on the rocker tip, you'd need play in that bearing. Right? And if you've got enough play to allow the amount of rocker tip movement pictured by the OP, then your chit won't hold together for very long.
YOU are thinking of old school stamped steel rockers found in Gen1s et. al. like this...
And yes, if you open up enough lash, those indeed can and will pivot side to side ever so slightly. That however is NOT the case on any rocker used in any LS series engine. You could install the f**king things without even putting pushrods or valves in at all and they still won't rotate like that. And if you can't look at that first picture and see that for your damned old self, then yes you are a good old fashioned idiot.
Get your head out of the 60's. This has been beaten to death over in C3 tech. It's not a necessary step. Maybe at one point it was, but I really doubt it. Lifters bleed down without oil pressure regardless. So if you did indeed need hydraulic pressure to set preload, then by the time you got to valve #16, you'd be working with a different torque setting than you did on valve #1.
And think about this. Are you pressurizing anything by soaking lifters in oil?
Old Nov 23, 2012 | 09:51 AM
  #37
lionelhutz's Avatar
lionelhutz
HTF does the arguement here has any relevance to the installation of rockers on this engine? You set the lifter pre-load by pushrod length and you install the rockers until they are tight at 22ft-lbs of torque. The lifter having oil in it or bleeding down doesn't make one rats-*** bit of difference on the installation of these rockers.
To Rocker arm rotates when torqued down
Old Nov 23, 2012 | 11:05 AM
  #38
wcsinx's Avatar
wcsinx
The lifter having oil in it or bleeding down doesn't make one rats-*** bit of difference on the installation of any hydraulic lifters.
fixed
Old Nov 23, 2012 | 12:20 PM
  #39
lionelhutz's Avatar
lionelhutz
It wasn't wrong. What you wrote is true too. However, on an older SB adjusting the lifters the first time empty or filled with oil could "feel" a little different. You still want the same end result.
Not that it matters here, but I typically do the rockers before installing the intake on an SB or BB so I can look at the lifter preload. Then, I install the intake and before firing pre-oil until I have oil at all the rockers.
Old Nov 23, 2012 | 09:18 PM
  #40
wcsinx's Avatar
wcsinx
I know. I wasn't actually correcting you...just using you really
