Oil pressure
Old Nov 21, 2012 | 12:26 AM
jward2496's Avatar
jward2496
Default Oil pressure
Ok, my oil pressure went to 0 psi on the gage then on the dic. The oil level is fine. Is my unit going out or my pump. The engine is not making any noise. I need help please
Old Nov 21, 2012 | 12:49 AM
cdkcorvette7's Avatar
cdkcorvette7
Please pull and post your DTC's. Procedure below:
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Nov 21, 2012 | 12:50 AM
jward2496's Avatar
jward2496
I let the engine cool and restarted it. Oil pressure not 33-35 psi. But it was bouncing about 5 psi each way. Could it be the sending unit? It was replced about a year ago. Cheap auto zone unit.
Old Nov 21, 2012 | 01:06 AM
dblerman's Avatar
dblerman
It's most likely the sending unit. If you really had 0 PSI you would know it.
For what it's worth, people have had brand new sending units crap out on them right out of the box.
Old Nov 21, 2012 | 01:11 AM
jward2496's Avatar
jward2496
Ok pulled codes 2264,2262,2605,2100, 2723 all b code and h then one code of u1064h
Old Nov 21, 2012 | 01:12 AM
cdkcorvette7
When the sending units fail the gauge pegs high not low... I wouldn't assume anything when your dealing with something as critical as oil pressure...
Year and mileage of your C5 would also be useful
Old Nov 21, 2012 | 01:17 AM
C5Natie's Avatar
C5Natie
And the Autozone sensors are actually decent units. I forgot who makes them but mine has been flawless for 3yrs now. Ive seen more oem sensors crap out right away.
Old Nov 21, 2012 | 01:38 AM
kabluie's Avatar
kabluie
Read the stickys at the top of the tech section and also the C5 general section. In those stickies it mentions that many electrical problems can be solved by cleaning the grounds. Those stickys will tell you where the ground connections are located. There's a bunch of them too. If you think about it you can see that all of the systems are connected at some point, and if one of the ground points is bad, then the systems that use that ground point will go to ground at another ground point. What ever systems they pass through will also show error codes.
Bear in mind that I'm a rookie with the C5. I've owned other exotic cars but each model of automobile is different. I recommend reading all the stickies at the top of the tech and general pages and perhaps you can see how to fix your problems.
Good luck with it.
Old Nov 21, 2012 | 07:54 AM
sunchaser73's Avatar
sunchaser73
One thing you could try is to connect a mechanical gage at the temperature sender housing and see what your oil pressure is. IMO that would be the best way to determine if your pressure sender is the problem or if it is something else.
Old Nov 21, 2012 | 01:32 PM
Slick Rick's Avatar
Slick Rick
I agree, Auto zone went back to the bronze ones about that time. I snagged one put it in and havnt had a problem sense......
Old Nov 22, 2012 | 10:54 AM
cptinjak's Avatar
cptinjak
Not true. They can fail causing a high reading, a low reading, or erratic reading.
One thing to check is the contacts in the 3 pin connector. Some get loose and need to be bent outward to provide solid contact.
Jack
Old Nov 22, 2012 | 04:19 PM
jward2496's Avatar
jward2496
Ok put a new sending unit in. Looks good. Cleaned up the wires and put new dielectric grease on them. I have not had t problem yet.
Old Nov 22, 2012 | 04:37 PM
dblerman's Avatar
dblerman
Always glad to hear it was something simple
Old Nov 22, 2012 | 11:15 PM
Hope that it is only the sending unit. Just keep an eye on things.
To Oil pressure
