P0803 code but the Eliminator resistor is good
I'll start from the beginning. Always a good place to do that...
I bought my '99 FRC almost 2 years ago and it had a skip shift eliminator already installed. Up until about a week ago it was working perfectly. Then I noticed an occasional difficulty pushing the shifter through the reverse gate. Nothing much. Just a little "stickiness".
Yesterday was different. I parked in the local metal supply to pick up the plate material for my tunnel plate. When I tried to put her in reverse she balked. Completely. The DTC code showed the P0803C and refused to clear. So I waited a few minutes until the parking lot was clear and pushed her backwards. (Nothing as embarrassing as having a bitchy girl-friend throw a temper-tantrum in public ;-))
I got her home and still no reverse.
So I searched the forum and found many references to the resistor burning out in the Eliminator. So I now have her butt up in the air and the Eliminator in my hands.
But the resistor shows conductivity and 16Ω!
Is this possibly a fault in the PCM or could the tranni be low on fluid? There is a bit of a leak and I'll check the level in a few minutes.
Unless the Lock Out Solenoid is bad (and the solenoids are well known to sieze up), you should be able to PUSH THRU the block gate. It takes a bit of force. (I think its 25 lbs) but, it should be able to still get into reverse.
Yeppers. The fuse was blown. #19
Does anyone happen to know what size socket fits the solenoid? My fingers estimate 1-3/8".
Thanks Bill for setting me straight on where to look for the problem
