Who makes Rocker Arm Studs for the LS engine?
Old Nov 22, 2012 | 03:08 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Who makes Rocker Arm Studs for the LS engine?
Hi Everyone,
I have searched and can't find anything on using studs on the rocker arms on the LS7 heads. I Have had to remove my rockers a few times and I worry about the aluminum head stripping. I have Yella Terra's on it.
Thanks for any advice!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Nov 23, 2012 | 01:18 AM
RonSSNova's Avatar
RonSSNova
Have you talked to ARP?
I bet they could make you some along with a custom nut that works perfect with the YT rockers. Shoot, they might even consider making it a product.
When I did all of my valvetrain setup work, I used some Olds Quad 4 intake manifold studs and nuts. Not good enough for actually running the engine, but made assembly and disassembly easy especially when setting up pushrod length.
Ron
Old Nov 23, 2012 | 08:55 AM
vettenuts's Avatar
vettenuts
Most of the studs I have seen are for stud mounted rockers. Crane and I believe Comp makes them. Not sure if the length will work correctly, but the bottom is the 8X1.25mm and the top is a SAE thread.
I used to run the Crane rockers and found that whenever I removed the top lock nut the stud would still back out and this was with using red Loctite. If this occurs, I am not sure you will resolve the problem of not running the threads in and out.
A better solution may just be to ensure you follow the correct procedure for the rockers being used, which for GM would be one procedure and for Yella Terra another, although the Yella Terra method of one cylinder at a time with the lifters on the base circle would also work for the GM rockers.
Old Nov 23, 2012 | 01:51 PM
SacCityCorvette
Supporting Vendor
I'm not 100% sure yet but it looks like the small ARP head studs might be the correct size? Anyone ever try them?
Thanks!
To Who makes Rocker Arm Studs for the LS engine?
