Spark Plug Wire Sparks Question...
Old Nov 23, 2012 | 02:05 PM
Ed2016's Avatar
Ed2016
Default Spark Plug Wire Sparks Question...
Hi guys,
I was changing the spark plugs and wires on my 99 C5 yesteday and decided to try putting cool tape on the ends of the spark plug wire (where it connects to the plug).
Since I have headers I thought it might help with the heat around the wires that come close to touching the headers.
The car runs fine and there are no codes. But when I look closely at where I put the cool tape I see small glowing bits (sparks?) while the car is running.
Is that something I should be concerned about? Could the tape be causing the sparks? I had no issues before I put the cool tape on.
Heres how I applied the tape (see photo below).
Also does anyone know what the part I have the yellow arrow pointing to is called/does?
Thanks,
-Ed
Old Nov 23, 2012 | 02:56 PM
PhilsFRC's Avatar
PhilsFRC
I would think the tape is probably metal based, and you're now providing a voltage path from the wire to ground (the sparkplug shields), rather than ONLY through the electrode. I would remove it. If you're really concerned about header heat, get some Koolsocks (sp?) or other similar hi-temp sparkplug wire insulation sleeves.
Yellow arrow-part of the air injection system for the left bank of cylinders that's part of the emission control system.
Old Nov 23, 2012 | 05:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GM Red Performance wires are excellent wires and really dont need help to resist the heat. Just use the GM Heat shields and you should be good.
Get rid of that tape.
Yes,, the thing you asked about is the A.I.R. (Air Injection Reaction check valve. The A.I.R Pump inject air into the cats to help them light off earlier when the engine is cold.
Bill
Old Nov 23, 2012 | 07:46 PM
Ed2016's Avatar
Ed2016
Tape removed... problem gone... Thanks guys.
-Ed
Old Nov 24, 2012 | 03:26 AM
C5Natie's Avatar
C5Natie
Same thing happened to me. I found it by looking under the hood at night. That header tape uses an aluminum backing.
To Spark Plug Wire Sparks Question...
