Memory loss...
Old Nov 28, 2012 | 12:43 AM
dman730's Avatar
dman730
8th Gear
Default Memory loss...
New to me 2001 vert. Radio stations as well as seat memories fail. When I drive I reset them but they don't stay. I turn off the car, restart and the settings are gone. I could assume it was the constant on the radio but the seats/mirrors too... I'm at a loss.
Anyone got any idea?
Old Nov 28, 2012 | 02:04 AM
NukeC5's Avatar
NukeC5
Same issue since I got my 99 too, minus the radio stations.
Old Nov 28, 2012 | 03:15 AM
striper's Avatar
striper
I think it's time for a new battery.
Old Nov 28, 2012 | 07:24 AM
dbaker's Avatar
dbaker
Yep,I had the same problem on a 7 yr old battery.New batt cleared up a few elec gremlins.
\db2
carolina
Old Nov 28, 2012 | 09:29 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
When you set the memory, are you holding down the memory buttons long enough to hear the two-beep confirmation signal?
Old Nov 28, 2012 | 12:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Put a DC Volt meter on the battery terminals. Have someone COLD START the engine and observe how LOW the battery output voltage drops.
If it drops below 10 VDC, you have a battery issue and need to recharge it or if its OLD replace it. That will solve your issues.
NOTE. Each time it does this, your PCM will report EMISSIONS NOT READY if you ever have to take it to the emissions station for sa recheck.
BC
Old Nov 28, 2012 | 02:41 PM
RonSSNova's Avatar
RonSSNova
Happened to me just yesterday. Batt was weak when I started in the AM. But no issues. Cold start again leaving work, the clock reset.
Hmmm. the batt charged up with the charger rather quickly, but still may be bad.
The interesting thing about these car is that with the gear reduction starter, the batt can be rather poor, but the car will still start. They just don't draw the massive current like to older starters do.
If you feel the batt is new, time to start looking for unexpected current draw when the car is parked. I need to do that as well.
Ron
Old Dec 1, 2012 | 03:40 PM
dman730's Avatar
dman730
8th Gear
The thing is that the battery is a brand new yellow top optima. I don't think it is an issue. VERY good voltage. I'm confused.
Old Dec 1, 2012 | 04:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,, If all you say is factual,,,you either have a bad connection somewhere or the memory module is losing power.
-Check the battery connections Tighten to 11ft/lbs torque 97-03 C5
- Loose dirty connections on the module
- Loose or corroded fuses in the fuse box.
BC
Old Dec 2, 2012 | 07:28 AM
Quicksilver Vert 01
The Optima Yellow Top is a deep cycle battery, and not intended to be used as a starting battery. It might be causing a low voltage problem, while the engine is cranking, which could cause the memory loss.
Measure the voltage at the battery terminals while you crank the engine for about 10 seconds. It should not drop below 10 volts while cranking. (Holding the gas pedal to the floor will prevent the engine from starting during the test.)
To Memory loss...
