LG cam question
Old Nov 30, 2012 | 10:49 AM
04MSZ06's Avatar
04MSZ06
Default LG cam question
I'm looking for some decent gains and I've decided to upgrade my 2000 FRC's cam. I've been doing some extensive research and I can't find a definite answer as to what cam will pass California emissions. The only thing I'm seeing is the Thunder Racing TR224/224 will pass easily. I would rather go with an LG cam (either the G5XE or G5X1). Can anyone give some insight with either of these choices as far as California emissions are concerned?
Old Nov 30, 2012 | 11:01 AM
mickey_7106's Avatar
mickey_7106
i believe the G2 will be the only one that passes the sniffer. but your better off talking to rick at synergy
Old Nov 30, 2012 | 12:29 PM
04MSZ06's Avatar
04MSZ06
Is Synergy out of Fremont? I'll check them out.
Old Dec 1, 2012 | 03:02 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I have had bigger cams pass. I would talk to Rick as well. He is a dealer of ours and can tell you better as far as the tuning required to do so.
Old Dec 4, 2012 | 07:18 PM
mickey_7106
Yes
Old Dec 5, 2012 | 10:58 PM
A.R. Shale Targa's Avatar
A.R. Shale Targa
The largest I've seen on the Tech Forums that passed was a 226 deg.
with a wider 114 or 116 lobe separation and the fella had his heads
milled like .030" or .035" which obviously jacked the compression ratio
up to help smooth out the duration.....proper tune assumed.
To LG cam question
