12 disc CD Changer Problem
Old Dec 4, 2012 | 02:39 PM
Jim Bullitt's Avatar
Jim Bullitt
Default 12 disc CD Changer Problem
I just tried to remove one of my cartridges from the player and it will not come out. It seems to cycle but starts and stops as is goes through the cd's then it just stops and does not pop out as it is supposed to. HELP !!!
Old Dec 4, 2012 | 02:50 PM
rwlc5's Avatar
rwlc5
There is a very small reset button on the changer that you press with a paper clip. That might help.
Old Dec 4, 2012 | 03:11 PM
Trios's Avatar
Trios
...People still use CDs?
Old Dec 4, 2012 | 05:22 PM
Jim Bullitt
Default 112 Disc Changer
Tried the reset button did't help.
Old Dec 7, 2012 | 06:52 PM
GCG's Avatar
GCG
If you remove the changer from your car and open its cover you will see that it is basically divided in 2 areas placed side-by-side, one to accommodate the magazine and another one where the selected disc gets extracted to and played.
Below the area that holds the loaded magazine, approximately centered with respect to it and opposite the loading door, there is a white plastic lever. If you action that lever it will unlock the magazine. Just be careful because one of the trays or CDs might be stuck half way between the magazine and the playing area, preventing you from freely pulling the magazine.
Be gentle and you should have no problem. Hope this helps!
Old Dec 8, 2012 | 12:04 PM
Jim Bullitt
Thanks, for al the suggestions I got it fixed and am now enjoying my music agai.
Old Dec 8, 2012 | 12:36 PM
GCG's Avatar
GCG
I'm glad you're back in business!
What did you do?
Old Dec 8, 2012 | 05:46 PM
johnson-rod's Avatar
johnson-rod
Yes, son. Some of us still use tapes too.
To 12 disc CD Changer Problem
