best fluid for '99 T56?
Old Dec 4, 2012 | 04:39 PM
crazydave's Avatar
crazydave
Default best fluid for '99 T56?
I had my tranny rebuilt, but now it has this annoying whine in 1-3 from 2k rpm+. I don't know what the shop filled it with, but is this something that the right fluid can fix, or does it need more than that?
Old Dec 4, 2012 | 05:07 PM
FKING1's Avatar
FKING1
If U have a whine IMO transmission fluid will not correct it.
Old Dec 4, 2012 | 09:19 PM
cptinjak's Avatar
cptinjak
Might be over-shimmed, hard to tell without seeing/hearing it, but either way I'd get it back to the people that built it ASAP.
Jack
Old Dec 4, 2012 | 09:44 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
The shop probably effed up the rebuild
Old Dec 4, 2012 | 11:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Fluid most likely will NOT fix your issue. Take it back. As long as there is ATF in it, your fine
BC
Old Dec 7, 2012 | 01:18 PM
crazydave's Avatar
crazydave
The shop owner wants to try a different fluid that he's calling "Impact" by MTL. I did some googling and it looks like MTL is a Red Line brand, but there's nothing made by them by that name. He says it is a heavier oil that can even quiet a ZF. Anyone heard of this before? I'm concerned about doing damage to those paper blocker rings in the early T56's with any other fluid, plus I also feel like it's trying to cover up something that is wrong, like adding thick oil to an engine with rod knock. He doesn't seem to think it's a problem worthy of removing the trans to fix it, because he says his hearing's not so good and he can't hear anything and doesn't understand why I'm making a fuss about it.
Old Dec 7, 2012 | 01:26 PM
NukeC5's Avatar
NukeC5
Of course its not worth removing to him. Its not his car, and he doesnt get paid for it. Having to put non-called-for fluid in to fix a problem lets you know it is not correct. Besides, that wont fix it. Its just a temporary fix that he hopes will quiet it down long enough to get you off his back. Then when it returns, it will be too late to get the work done at no cost. My opinion anyway.
Old Dec 7, 2012 | 04:16 PM
cptinjak's Avatar
cptinjak
If possible, a high quality video could possibly help us diagnose the sound more accurately. We can not be SURE it is the transmission, really. Could be a pilot bearing, TT bearing, diff, etc. The TT acts like a megaphone, and sounds can sound like they are coming from a totally different location than where they originate. Perhaps getting under the car on a lift while it is running and using a stethoscope could help you make sure you have the source.
I would GUESS the trans is shimmed improperly, but that is based only on the assumption that the noise immediately after the rebuild is not coincidence, combined with the assumption that the person that rebuilt it doesn't do quality work. Both assumptions, both could be very wrong.
Jack
Old Dec 7, 2012 | 04:21 PM
crazydave's Avatar
crazydave
I was trying to keep the explanation simple, but you're delving deeper so I should mention that this is a rebuilt trans originally from a different car.
Old Dec 7, 2012 | 04:23 PM
cptinjak's Avatar
cptinjak
The simple answer is:
Fluid will not remedy an improperly shimmed transmission.
Jack
Old Dec 7, 2012 | 04:24 PM
cptinjak's Avatar
cptinjak
My reason for delving deeper is that in order to do a transmission, you have to remove the input of the propshaft from the pilot bearing, remove the output of the trans from the diff, remove the input of the trans from the TT, etc etc etc.
A lot of things could have been damaged and now cause a whining noise.
Jack
Old Dec 7, 2012 | 04:34 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I would think he would not have rebuilt it with the old paper blocker rings. Are you sure the trans has the paper rings?
Old Dec 7, 2012 | 04:44 PM
crazydave's Avatar
crazydave
Apparently so...
Old Dec 7, 2012 | 11:08 PM
crazydave's Avatar
crazydave
Here's a quick audio sample of the noise it makes.
Click for audio
Old Dec 9, 2012 | 04:45 AM
cptinjak's Avatar
cptinjak
Hate to say it, but that sounds over-shimmed to me.
Jack
Old Dec 9, 2012 | 07:59 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
From the best transmission builders in the world, "use red fluid", I have never had a trans builder stand behind any of the big dollar fluid options
To best fluid for '99 T56?
