alternator overcharging
Examine the schematic below:
The RED wire that connects on the starter solenoid and runs up to the alternator connector pin "D" must be at battery voltage potential. You will also see that it has a fusable link in that wire. With the engine OFF, disconnect that connector on top of the alternator and measure pin D to chassis ground. You should see full battery voltage on that pin.
The BATT terminal on the back of the alternator should also have full battery voltage on it.
That red wire is what the alternator uses to control output. If it is LESS than battery voltage, the alternator regulator will continue to increase battery voltage until it either reaches the normal output or goes to maximium output.
Here is where it connects to the starter solenoid and where the fusable link is:
The dealer is likely saying PCM because the tech sees the wires going to the PCM. When there is something wrong that appears electrical the tech just starts replacing every part that has a connection. So, alternator swapped without luck means the PCM must be bad. They might suggest the starter next (even though the solenoid post is just used as a connection block). A lot of techs have no clue how to actually troubleshoot. Test for bad wiring? Good luck having that happen.
It's possible you have multiple issues, but at least get the alternator producing the correct voltage before worrying about other things which might be wrong.
The PCM provides the Field Duty Cycle Signal, which is used to control the output voltage of the alternator.
The Field Duty Cycle Signal is a precise Pulse Width Modulated control of the alternator field turn-on. The PCM determines the duty cycle, based on the voltage reference signal it receives.
The bottom line here is yes, the PCM controls the alternator output voltage on C5 Corvettes.
I was incorrect stating that the PCM sends the field duty cycle signal. The PCM only monitors the signal for charging system faults. The actual field duty cycle signal originates from the internal voltage regulator in the alternator.
Here is some good info on the charging system.
http://forums.corvetteforum.com/1558326606-post9.html
