PCM code
Old Dec 12, 2012 | 07:41 PM
rodsvet's Avatar
rodsvet
Default PCM code
I have a question to you computer wizards. My check engine light came on last night. All the vitals are ok. The only code in the dic was PCM7051H. My manuals don't list anything like that. Any one have an idea? I cleared the codes and it hasn't come back on yet. 2000 A4 44,000 supercharged. Thank you, Rod
Old Dec 13, 2012 | 06:43 PM
dannyman's Avatar
dannyman
Suspect the code was P0751H
"1-2 Shift Solenoid Valve Performance"
The H indicating that the code was History and not a Current code. If still current it would have registered as P0751HC.
If the solenoid valve performance issue re-surfaces, so will the code.
Dan
Old Dec 13, 2012 | 07:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clear the DTC, reread the DTCs and see if it returns.
Old Dec 14, 2012 | 12:23 AM
rodsvet's Avatar
rodsvet
Thanks guys! I will take the car out if it stops raining and get it into boost and see if the code returns. It did come on right after I got into it a little. (a lot) Rod
To PCM code
