Quick Disconnect Question! {Slave}
Old Dec 13, 2012 | 08:19 PM
blackula 99's Avatar
blackula 99
Default Quick Disconnect Question! {Slave}
Installed a new Clutch master cylinder.
Disconnecting the slave quick disconnect wasn't to bad, My problem is now trying to reconnect. I have read that if you crack the bleeder screw a bit it will relieve pressure in the system and it makes it easier to reconnect but in the process you would draw air into the system correct?. I know it's very difficult to gravity bleed these cars, do I have any other recourse or is this the accepted way to reconnect slave line and in turn just bleed the system? I do have a power bleeder and have had good results with that but is all of this necessary just to get the quick disconnect back together? Thanx again for for any input !
Old Dec 13, 2012 | 08:47 PM
shadowman1's Avatar
shadowman1
You are going to bleed it anyway and the amount you would get in (if any) wouldnt matter much. You would be pushing fluid out the bleeder as the hose goes in. No extra air should enter.
Dave
Old Dec 14, 2012 | 07:51 AM
bumble-z's Avatar
bumble-z
Feedback...
Let us know how you made out with the Quick disconnect (connecting) problem.
To Quick Disconnect Question! {Slave}
