Critique my ls7 setup.
Okay so I had my ls7 swap tuned by a local guy and he did a fantastic job. The car drives great and pulls hard. It has great manners and does everything I want it to. However, I was expecting a little better numbers and wanted some opinions on how I can pick up more power.
Setup
Ls7 with Mahle forged pistons, 11.4 to 1 compression
Valve job and new exhaust valves
stock ls7 intake
1 5/8 slp longtubes with slp x pipe and hi flow cats through a stock z06 exhaust.
stock new rockers
lethal cam from ragin racing 230/ 248 625 lift (low lift cam for PAC springs)
Heads decked .008 and block decked .008 for compression around 11.8?
lingenfelter 24 X converter
New rebuild with a couple hundred miles.
McCloud RST twin clutch
Stock fuel system ( have pump just in case but air fuel was ok)
stock MAF
Vararam intake
Air fuel is on the conservative side for preservation of ls7.
Now I know my exhaust is weak and I am using stock intake. Since I have forged pistons I already have a nitrous kit on the car and can add a quick 150 HP if needed. (standalone fuel system)
What are some suggestions? I would like 500 rwhp on a mustang dyno.
There are a few of things you "could" change to increase the power that shouldn't change the characteristics of the build.
1. Get some ARH 1 7/8 LT's on there
2. Go with an LS2/3/7 MAF in front of the 90mm TB
3. Have the dyno operator manipulate the numbers. Lot's do it.
Here's a long thread on the development of my very mild but highly optimized build. You may find some ideas there. It goes all the way from the 403 build to the 427.
http://ls1tech.com/forums/generation...b-c-d-e-f.html
Did you have the heads flowed? If so, are you getting enough valve lift to maximize air/exhaust flow?
As others have said, there are areas in which you can improve flow through the engine:
1) larger headers...go for the gusto and get 1-7/8"
2) larger intake OR port the one you have
3) larger throttle body and MAF
I have 408 cu. in. (11.1 CR) with a FAST 102mm intake, Nick Williams 102mm throttle body, Kooks 1-7/8" LTs and a 3" x-pipe. My engine tuner went with a speed density tune.
Post-build I had 603 hp/503 ft-lb on the engine dyno and 518 hp/440 ft-lb on Dynojet.
Hope this helps...
I get what you guys are saying and thanks for the input. The extra 30rwhp looks like 2500 bucks some of which can be offset by selling the stock stuff.
Transbrace make a huge difference in keeping the tranny alive? How hard are they to install? I am not very familiar with them.
