2001 Headlight Motor
Old Dec 18, 2012 | 06:41 PM
JohnnyB's Avatar
JohnnyB
Default 2001 Headlight Motor
Motor keeps running about 5 sec AFTER CLOSING. Sounds like motor like a grinding sound. It is the Mechanisim that is right on headlight area. Only on closing. Can feel the loud and hear vibration, any help ?
Old Dec 18, 2012 | 07:48 PM
fastyellowss's Avatar
fastyellowss
Mine started doing the same in my 2001 just days before winter storage. Hopefully somebody replies with the fix.
Old Dec 18, 2012 | 08:05 PM
JohnnyB's Avatar
JohnnyB
I had the same problem a few moths ago with the other side, if I remember is was not real expensive to do. The way that little device looks it may be fixed by yourself but I will wait for a reply.
Old Dec 18, 2012 | 10:01 PM
butch2000's Avatar
butch2000
The gear is plastic , and the teeth are geting stripped off , causing the skip , it will get worse , very easy fix , if you look it up under your favorite corvette parts supplier , there are lots here , about $50 for the kit , and about an Hour to fix if you take your time , very easy fix , the replacement gear will be metal , to prevent this happening again
Old Dec 21, 2012 | 11:04 AM
JohnnyB's Avatar
JohnnyB
Thanks Butch, ordered gear online, does not look difficult to replace but as in any vette looks are deceiving
Old Dec 21, 2012 | 12:12 PM
butch2000's Avatar
butch2000
LOL, your right , but it is fairly easy just take your time , Merry X-mas !
Old Dec 21, 2012 | 02:33 PM
oh1vette's Avatar
oh1vette
http://forums.corvetteforum.com/c5-g...errerid=228945
Old Dec 22, 2012 | 11:43 AM
borkg2006's Avatar
borkg2006
Check out RodneyDickman.com. He makes gears etc. for nearlyl all flip-up lights. Has a great rebuild kit for C5's
Old Jan 1, 2013 | 08:44 PM
JohnnyB's Avatar
JohnnyB
Thanks for everyones assistance, all OK after buying steel gear and directions. Great job Corvette Forum. Thanks Rodney Dickman for your assistance and product. Suggest to all with this problem call Rod !
Old Jan 1, 2013 | 08:58 PM
tjones524's Avatar
tjones524
Looks promising.
My right side headlight doesn't make noise, but it has stopped halfway quite a few times and i had to turn it off and back on for it go up fully ( passenger side ) it also like shakes weird when it goes up and down, not smooth at all, wonder if this could be a chewed up tooth or two on the gear causing it.
Old Jan 1, 2013 | 10:48 PM
Dave68's Avatar
Dave68
It could very well be. I replaced both gear sets in my 01, last year. Patches' DIY tutorial was helpful, as was the kit from Rodney.
To 2001 Headlight Motor
