Manual Heater Temp Control inoperable
For: Y A/C MAN CONT(C60) (1997-2001) (1997 - 2001).
GM part # 89018681 $45.72 at gmpartseast
AC Delco part # 15-73627 $34.30 at amazon
On the broken unit you pictured and I commented on, the vacuum manifold controls the air outlet-where it comes out-defrost/floor heat/dash vents/etc.. If that is working, I'd be leaning toward the above mentioned actuator (and a broken gear as Bill indicated). Good luck.
P.S.-DOES look like it has reference marks at full hot and cold as well as at a "center" position shown on the picture of the new part. That will definitely come into play installing/indexing the new one.
Awoke today with what I hope is a 24-hour wellness problem. Before I started looking at anything, I took the car out for half an hour since the weather was dry and the car had not been started for three months except for Thursday.
I left the temperature control in Full Hot yesterday afternoon. Today I had hot air from the heater.
For grins, I set the control back to Full Cold when returning, but no response. (Hey, magic can't happen?
)Notes unrelated to temperature control:
I put the passenger fuse box cover on with the open end pointed up rather than down. The d*mn thing would not seat where the screw would catch. SO the Fuse Relay Center lettering is upside down & under the flexible trim under the dash. They put two threaded holes in the fuse box floor, so why not use it?
(But there must be a reason they had the open end down from the factory. Udder Drainage?)
The left front turn signal/DRL bulb died while I was out. No problem. I have a spare & it's a 15 minute job, right? Removed the headlight shroud, popped the the socket out & pulled the bulb easily. But then I dropped the replacement bulb into the bowels of the underhood pit when I tried to seat it. Let me say that finding that bulb was easier than finding the headlight shroud screw that I once dropped years ago, but it still took 15-20 minutes.
And the results of these two efforts, along with my nose performing a Niagara Falls impression with minor volcanic eruptions, is why I did not drop the lower panel on the dash today. "You gotta know when to fold 'em"
I just got done replacing the steering wheel position sensor, and soon as I was done the HVAC no longer adjusts for driver or passenger. I have the same scenario where vents and fan speed are completely adjustable, but the temperature stays on full hot regardless of where I set the temp on the HVAC controls.
Is there something that I could have disconnected or screwed up while I was in there that would have blocked or disabled the blend door / actuator? The car is a 2002 Z06 with dual climate, and there are no active or history HVAC codes.
Thanks in advance for any ideas or suggestions you can toss my way.
Now I get the fun of replacing the one on the passenger side too, far as I can tell the dash has to come out for that, starting up a new thread to see if there are any shortcuts...
