Moisture Problem inside C5 Convertible
Old Dec 31, 2012 | 09:31 AM
nnicholas's Avatar
nnicholas
Default Moisture Problem inside C5 Convertible
All
I just purchased a 2001 C5 Convertible and I have a mositure problem where the windows fog up inside and inside, on the bottom of the trunk lid, water droplets form and when I open the trunk the water drips on the carpet. Any Ideas???
thanks
Nick
Old Dec 31, 2012 | 11:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Nick
You have a LEAK somewhere inside the car. Remove the carpets, and find the WET carpet underlayment!!
Check the drivers & Passengers carpet under the seat AND the trunk carpet and trunk stowage wells for water / moisture.
When you find the wet carperts, REMOVE THEM!! That way, you can see excatly where the water is entering the car. If you dont remove and dry the carpets, they will MOLD and Mildue and STINK! Trust me! Been there ,, ,DONE THAT!
When ever you can,, leave the windows down so the moisture that has already eveaprated and condensated can leave the car.
BC
Old Dec 31, 2012 | 11:50 AM
nnicholas's Avatar
nnicholas
Thanks Bill.
I hope to have my garage cleaned out where I can put it in and work on about 5 issues the next couple of months. I will take out the carpets first thing.
Old Jan 1, 2013 | 12:49 PM
Ricbear's Avatar
Ricbear
Go get some DampRid and put in the car will help remove some of the moisture.
Old Jan 1, 2013 | 01:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It will remove what moisture is there but it you dont fix the leak, you better buy stock in DAMPRID, You will be buying that stuff forever......
BC
To Moisture Problem inside C5 Convertible
