TPMS when buying new tires...
Edit to add; I'm new here, where do I find Gene? Thanks, Bob
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $41.37 each
15234846 – nuts – $4.03 each
Total setup of 4 is $181.60
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
Are these parts to rebuild the units or complete units? This is my first hobby car that is modern enough to have TPMS and I am clueless.
If you don't fit TPMs you'll get a DIC warning every time you start the car. The warning can be programmed out with a Tech II.
Tire Pressure Monitoring Sensor Programming
The Tire Pressure Monitor (TPM) system interfaces with the Instrument Panel Cluster (IPC) through the serial data line. Once the program mode is accessed through the IPC, each sensor's unique identification code can be programmed into the receiver's memory. Each sensor must transmit the unique code in the proper sequence. A magnet must be held close to the sensor in order to force the sensor to transmit the identification code. The IPC will display a message as each sensor is programmed, and when to proceed to the next sensor for programming. The receiver also sends a message to the BCM to sound the horn one time, indicating that the sensor properly transmitted an identification code. If the programming sequence is cancelled before any sensor is programmed, or if the vehicle's battery is disconnected, the receiver will remember all current identification codes. As soon as the receiver learns the first sensor identification code, all previously stored codes are erased from the receiver's memory.
J 41760 Tire Pressure Monitor (TPM) Programming Tool.
Tool required (any medium strength magnet, U or Disk type
1. Turn the ignition to ON.
2. Press the RESET button in order to clear any IPC display warning messages.
3. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
4. Press and hold the DIC RESET button for 3 seconds.
Notice: Refer to Body Control Module (BCM) Programming/RPO Configuration in Cautions and Notices.
5. Press the OPTIONS button again until the TIRE TRAINING message appears.
6. Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin
the programming sequence.
7. Install the J 41760 Tire Pressure Programming Tool over the left front valve stem.
8. The horn will sound, indicating the left front TPM sensor is programmed.
9. When the horn sounds, proceed to program the next TPM sensor in the following order as directed
by the IPC messages:
- LEARN R FRONT TIRE
- LEARN R REAR TIRE
- LEARN L REAR TIRE
Programming Cancellation
1. The programming mode will be cancelled if any of the following conditions are met: - The program mode is exited through the DIC.
- The ignition is turned to OFF.
- All four sensors have been programmed.
- The TPM system has been in the program mode for longer than 2 minutes and no sensors
have been learned.
2. If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point
Just consider, in the old days, new tires automatically meant new valve stems. Today, it's a little more complicated (and expensive), because the "nanny state" thinks we don't know how to use a tire gauge, so they mandated TPMS....
http://www.amazon.com/ACDelco-257739.../dp/B000J9Y1T8
Is Tech II a device that is readily available? I would rather monitor my tire pressure the old fashioned way. If I go with conventional valves and can't program out the DIC warning I guess I could live with the minor annoyance as long as it didn't affect anything else. Thanks, Bob
The Tech II is primarily a dealer tool, but if you really wanted one badly enough to spend the money (serious $$), they pop up on E-bay sometimes, and you can get a bargain.
Once I program/activate the new TPMS will the old ones in the wheel no longer work (they are working now but 10 years old)?
Yes...
They would "work", but the car won't read them, as you set it to read the new ones...
