From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Valvespring Swap Help
I'm having trouble wrapping my mind around the how tos of getting air into the cylinder to hold the valves up.
What equipment do I need and from where can I get it?
Thanks for the help!
I've heard of that method. How much of a gap is there between the piston and the valve? In other words, how far does the valve fall into the cylinder before it rests on the piston? I wonder why this method isn't used more often.
I used the air method, the last time I changed a set of valve springs, but it was on my '96 Camaro with an LT1, not my 'Vette with an LS1. You can get an air hose from many of the auto parts stores, and it has a fitting to connect to your air compressor at one end, and a fitting to screw into your spark plug hole on the other.
With the piston at TDC, the valve can only drop down 1/4" at most. If it does drop down just pull it back up. The valve stem seal usually holds it in place.
The air method works if you don't want to go to the trouble of finding TDC for each cylinder. However, I have seen the air method actually push the piston down and cause the motor to rotate at the most in opportune time.
Air method works great. You can find the fitting from most auto parts, you can also buy it at Summit Racing. Holds valve up great. I had no movement of the valve at all.
And then have a leak and start looking for the valve that dropped. Won't tell you how I found this out
I use the TDC method as well and I like using the rope trick even better because some of the lock can become quite stuck.
I am now clear on my direction. Thank you guys for the information. I will use the air method in conjunction with the TDC method. I will remove all rocker arms, which will close all valves then be sure to remove only one spark plug at a time to prevent the engine from spinning over on me. Thanks again.
When I changed my springs, I tried the air method as described and still spun the engine and heard some hissing. Wasn't to comfortable doing it that way so I resorted to the TDC and nylon string method. It's a little more time consuming but a very safe way of doing it, plus it was my first time doing them and I really took my time not knowing what to expect. Started on the passenger side and ended up at cylinder 1, that way you find TDC on compression stroke and start tightening rockers in correct order when done with springs.
you can buy the air fitting from speedinc, but honestly you really don't need it... once you remove the rockers the springs will seat the valves and the seal will hold it in place... if it does fall a little bit you can use a pen magnet to hold it up... the valves are longer than the stroke so even if they fall and the piston is at bdc they aren't going to fall in the cylinder and get lost... I left my hood on when I did my cam for 2 reasons, I didn't want to have to mess with realigning it and I did the job by myself so removing the hood really wasn't feasible although it would have helped... don't let the job intimidate you, you'll be fine
putting the piston at tdc then inserting a piece of rope in the spark plug hole... the rope fills up the space between the piston and valve to keep it from falling
