ceramic vs wrap
Old Jan 28, 2013 | 03:02 PM
Erics_02_z06's Avatar
Erics_02_z06
Default ceramic vs wrap
Finally got my headers out so it's time to coat/wrap them. Kooks headers. I've been reading that wrap ruins headers. This car is a weekend cruiser and doesn't see rain. About how long would they last wrapped?
Old Jan 28, 2013 | 03:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Drop the coin on the coating... You will be much happier!!! Your headers will also not crack and smell weird if they ever get wet!
Old Jan 28, 2013 | 03:20 PM
chaase's Avatar
chaase
St. Jude Donor '12
Do not wrap them. The wrap looks terrible and if it gets wet it will retain the moisture causing them to oxidize. If you feel the need to do anything, ceramic coat them.
Old Jan 28, 2013 | 03:39 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Oh good lord!!! Do not wrap them!
Either leave them bare or spend the money to have them ceramic coated!
Old Jan 28, 2013 | 03:43 PM
Erics_02_z06
ok, I'll go for the coating. They have a polished that is good for 1300, and a black good to 1600. What kind of exhaust temps are you seeing on a supercharged ls motor?
Old Jan 28, 2013 | 06:14 PM
tiojames's Avatar
tiojames
I would coat them inside and out. Check out Jet-Hot for the coating.
Old Jan 28, 2013 | 06:35 PM
LoneStarFRC's Avatar
LoneStarFRC
Jet-Hot is the leader in the technology for a very long time.
Old Jan 28, 2013 | 08:33 PM
StatmanRN's Avatar
StatmanRN
If you are looking for appearance, coating hands down. But the wraps dooes a much better job keeking heat out of the engine compartment. Had jet hot coated headers on my TA. You could still grill hot dogs near those. if you do wrap them, use the sealer.
BTW those were outside coat only... may be that the inside coating would have helped.
Old Jan 28, 2013 | 09:33 PM
lionelhutz's Avatar
lionelhutz
I've had coated and not coated headers on different cars. Really doesn't seem to make much difference in heat. Coated will still burn anything that touches them. But they do look nicer coated.
Old Jan 29, 2013 | 10:30 AM
ttz's Avatar
ttz
If heat is your main concern, do both. The coating will prevent any possible oxidation due to moisture retention.
Old Jan 29, 2013 | 10:49 AM
sean.b's Avatar
sean.b
could do it ye old Alabama special way, and spray it with grill paint. that stuff that's meant to be good to like 2000 degrees or whatnot.
hey, dont judge me. it works when you arent Jethot'ing them.
Old Jan 29, 2013 | 03:05 PM
Whistler's Avatar
Whistler
Keep in mind, the Kooks headers he's debating on are stainless. So while wrapping headers can trap moisture against the header if the car is sitting outside and not in use, stainless construction renders the moisture fairly inconsequential. Also the stainless material contains exhaust heat inside the pipe more effectively than mild steel, so the ceramic coating is more cosmetic than anything.
I personally wouldn't wrap anything unless it was turbo hotside components in a cramped engine bay. Once it cures it gets you itchy as hell when you work on the car.
To ceramic vs wrap
