Where is your catch can?
Old Jan 28, 2013 | 10:20 PM
FruiTay's Avatar
FruiTay
Default Where is your catch can?
Where did you install your catch can? Got some pics?
How easy was the install?
How's it workin' out for ya?
I ask because there is no specific place to install an oil catch can and this install not in the DIY thread.
Thanks guys!
Old Jan 28, 2013 | 10:26 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I'm glad you asked this question, I just bought an RX Monster can and this thing is Ginormous. With the supercharger and fuel pressure regulator, I don't know where this thing is going to go. Most guys relocate the battery to the trunk and put the can in battery area, but I'm going to do that crap!
Subscribed!
Old Jan 28, 2013 | 10:31 PM
Baldfart's Avatar
Baldfart
Old Jan 29, 2013 | 03:01 AM
Chris Stewart's Avatar
Chris Stewart
I like the Elite Engineering, it bolts right into the head. Mine needed a 1" bushing to clear in front of the fuel rail covers. I like knowing the junk shown below is not going thru the intake.
Old Jan 29, 2013 | 07:22 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
Mine is on the way! Bolts to the head. From Elite.
Old Jan 29, 2013 | 08:33 AM
sean.b's Avatar
sean.b
ill take pics when i get home, but mine is farther out than that. i wanted to keep it as cool as possible such as to promote condensation of the vapors. same exact principle as the above, just longer hoses/bolted it up farther out.
Old Jan 29, 2013 | 09:13 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I use a duel and it works great
Old Jan 29, 2013 | 06:51 PM
Zorlac's Avatar
Zorlac
I have an Elite and its mounted on the passenger side frame up front past the hood hinge. I've read that cooler is better. It works well. I'm trying to share a pic from my phone so it may not work.
https://skydrive.live.com/redir?resi...Nus0ZoRx5XBeVc
Old Jan 29, 2013 | 06:54 PM
sean.b's Avatar
sean.b
yep, same exact spot for me too.
Old Jan 31, 2013 | 11:42 PM
Dave68's Avatar
Dave68
Cooler is better, since the hotter the oil, the more likely it will get past the filter. Here's how I installed my unit:
http://www.conceptualpolymer.com/Ins...20Corvette.pdf
Old Jan 31, 2013 | 11:52 PM
NukeC5's Avatar
NukeC5
Mines right in line from the stock (exterior pcv valve) to the intake. The typical spot, but I have heard about moving it farther away to cool the oil more as well. Some members have put up pics showing it sitting on the front of the radiator shroud next to the intake. Might look into that.
Old Feb 1, 2013 | 12:47 PM
I bought mine from Elite Engineering - bolts to the head on the passenger side with supplied bolts and bracket. Only difficulty was getting one of the bolts started due to slim clearance. But overall, a pretty easy install and it works great.
Old Feb 1, 2013 | 01:26 PM
Rev Xtreme's Avatar
Rev Xtreme
St. Jude Donor '13
Old Feb 1, 2013 | 06:56 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
This can is a good one!!
Old Feb 3, 2013 | 07:04 PM
cdnguyred88's Avatar
cdnguyred88
Old Feb 4, 2013 | 03:56 PM
_zebra's Avatar
_zebra
currently have my CCA can bolted to the passenger head beside the tensioner, but i eventually want to move it up by the radiator so long as i can hide the hoses
Old Feb 4, 2013 | 04:25 PM
WKMCD's Avatar
WKMCD
I tried mounting mine on the frame rail in front of the radiator. At that length, the 3/8" ID hose proved to be too restrictive for the can to function properly. It was either move the can back up to the head or throw some big *** hose on it.
This is were it lives:
To Where is your catch can?
Old Feb 4, 2013 | 08:08 PM
_zebra's Avatar
_zebra
well that sucks. i didn't know about that little caveat - thanks for the heads-up
Old Feb 12, 2013 | 10:29 AM
Rev Xtreme's Avatar
Rev Xtreme
St. Jude Donor '13
All with a can.....for peace of mind, at any auto parts store pick up a $10 clear glass inline fuel filter and install it between your can and the intake manifold and see just how much oil is getting pulled through. Very simple, and then you are not taking marketing hype claims on how well any can works....see for yourself. ALL cans catch oil, even a beer can with 2 fittings in it (yes, we did it as a joke to see and it caught as much as most ebay cans), but it is what a can allows to "pull through" that matters. You want NO oil ingestion into the intake air charge......try it and post pictures.....most will be surprised to see the can they are using allows so much oil to still be ingested.
:thumbsup:
Old Feb 12, 2013 | 02:20 PM
Big_George_S's Avatar
Big_George_S
I bolted mine to the tensioner. STS had grabed the head bolt for one if its components and I did not want to do a long hose run to mount on the frame rail. True the cooler it is the better it will capature oil.
