breather catch can setups
Old Feb 4, 2013 | 08:30 PM
_zebra's Avatar
_zebra
Default breather catch can setups
for the catch can/PCV gurus out there...
i'm just curious as to how & why the airflow through a catch can is reversed when running a breather instead of a standard closed system.
simply applying my dumb redneck logic to the situation, the closed system makes sense in that oil vapors enter through the top, pass through the filter/condenser, and drip to the bottom allowing dry air to pass out the side at the top of the reservoir.
now if you put a breather on top of the can, you're running the airflow backwards - the oily air is entering through the side & passing up through the filter/condenser, then venting out the top. does this still allow the vapors to actually condense & drip to the bottom against the flow of air? it seems like the vapors would be pushed out the breather & collect on that filter element before having time to cool off. it seems like this would only really be effective if you had 2 catch cans rigged up in series: the first plumbed like a closed system & the second with a breather.
can somebody please explain this? thanks
Old Feb 5, 2013 | 10:22 AM
waddisme's Avatar
waddisme
Actually I am switching my catch can set up to that right now. Instead of routing the supposedly clean air back into the intake, I am going to run it out to a breather and into the open air. The jury is still out on whether or not it will smell too bad. Some say no, some say yes. Even the best catch cans do not get 100% of the oil so why even risk it. Just going to plug port on intake and see how it goes.
Old Feb 5, 2013 | 08:27 PM
robert miller's Avatar
robert miller
Let us know here on this... Robert
Old Feb 6, 2013 | 01:21 AM
_zebra's Avatar
_zebra
that's how i was advised by CCA to run at the track - reverse the plumbing on the can, put the breather on top, and plug the port. then for the street, undo that & run it closed
Old Feb 6, 2013 | 01:22 AM
_zebra's Avatar
_zebra
i was particularly asking how effective the separator element is when ran backwards
Old Feb 6, 2013 | 03:13 AM
ZeeOSix's Avatar
ZeeOSix
Problem with that setup is there is no vacuum working on the engine's crankcase, so you really don't get good evacuation which means there could be trapped condensation, etc inside the engine. I can see running an open breather on the track to help prevent oil ingestion through the intake manifold, but on the street it wouldn't ensure all the bad vapors are evacuated from the engine.
Old Feb 6, 2013 | 10:41 AM
ttz's Avatar
ttz
I personally think the best way to do it is a hybrid of both. What I did was cap off the "inlet" line running from the passenger cover to the tb. I then tapped the driver cover in the back where the plug is and ran that to a catch can. I also ran the valley cover line to the same catch can (LS6). I than ran a line from the catch can to the intake manifold with stock PCV valve. Finally I added a breather filter to the oil fill. What this does is allow the breather to act as an inlet so the stock system can still draw fresh air and get rid of any moisture in the crank case, but also allow it to vent through the breather if needed during WOT. It the breather ends up misting too much like some report then I'll run a line from the oil fill to a vented catch can so I works the exact same but would catch any mist.
Old Feb 6, 2013 | 12:29 PM
waddisme's Avatar
waddisme
I ran the p/s valve cover capped along with breather oil cap for a couple years. Problem is the oil port on the valve cover is not shielded like the valve cover port is. During track days, the rocker arms would throw oil right thru my ECS oil cap breather onto motor. So now I have a breather on the valve cover port (which is shielded underneath) and a stock oil cap. For just dd, the oil cap breather worked fine.
Old Feb 6, 2013 | 12:37 PM
waddisme's Avatar
waddisme
I was going on the assumption that there would be enough pressure to evacuate itself enough(PCV - Positive Crankcase Ventilation). But I see where you are coming from. It would take a whole 3 min to reroute plumbing for track days vs dd. That might be a better solution any way and the smell would be a non-issue. Glad you brought that up.
Old Feb 6, 2013 | 07:48 PM
ZeeOSix's Avatar
ZeeOSix
Only problem with that setup is the engine is getting more air than the mass flow sensor in the intake duct is measuring (ie, "metered air"). In the factory stock "closed" PCV system, the fresh air that enters the engine through the hose that runs from the intake duct right before the throttle body to the valve cover has already gone past the mass air flow sensor. But with that hose gone and an open breather on the oil filter cap, the air drawn into the engine (due to intake manifold vacuum) is un-metered so the engine is getting more air than it thinks it is.
Not sure if that's a big issue or not ... the ECU might be able to adjust for that. Haven't heard too many guys say their engine runs bad with an open breather setup so maybe the leaning out is minimal.
Old Feb 7, 2013 | 11:06 AM
ttz's Avatar
ttz
I should have meantioned I'm SD tune, so that's not an issue.
Old Feb 8, 2013 | 02:00 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
http://ls1tech.com/forums/generation...outing-ok.html
http://ls1tech.com/forums/11059703-post70.html
Old Apr 25, 2013 | 10:33 AM
waddisme's Avatar
waddisme
Just a quick update - I have changed my set up to block off port going back into intake and am running hose from valley cover to catch can to breather cap. So far no noticeable smell and 0% oil back into motor. If it works out for long term, I may just drop the catch can and run the breather directly out of valley cover port like Spinmonster's set up. You can go to C6 Tech section and there is a good thread on this set up along with oil analysis results etc.. HTH.
To breather catch can setups
