axle into differential
Old Feb 10, 2013 | 11:01 AM
xtremeironworks's Avatar
xtremeironworks
Default axle into differential
Hello All,
I just put in my 3.42 differential. Im at the point now i need to slide in the axels into each side of the differential. I just gave some good pulls and they slid right out. Is there a certain trick to sliding axels back in? Also every thing is connected on the other end of the axel. I pulled the whole crossmember complete when pulling out the differential.
Thanks for your help.
Old Feb 10, 2013 | 11:15 AM
RonSSNova's Avatar
RonSSNova
They take a little persuasion. You might add just a bit of gear oil to the splines and use a little thin grease on the outside of the axle where the seal runs.
Are you using stock GM axles? I remmember reading that a few folks have had issues with replacement parts not having good splines and being very hard to install.
Old Feb 10, 2013 | 11:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They can be a pain to get back in but,,,,,,,,,,, they will pop in. I had one so stubbron that I started the engine, put it in gear and massaged the CV housing to get it to pop over the spring clip!
BC
Old Feb 10, 2013 | 12:29 PM
bumble-z's Avatar
bumble-z
I'm assuming you don't have the upper arms connected.
If you do, take the bolts / nuts out to give a little play/wiggle room.
Old Feb 11, 2013 | 02:02 PM
Forrest101's Avatar
Forrest101
I just did diff swap, and yes they do pop in with a bit of effort. Control arms must not be bolted in>
To axle into differential
