Gremlin King Defeated....I think. (Long)
BCM was cleaned and examined again (heads up to anyone contemplating a visit into the BCM, the aluminum box that houses it will come apart with bending during the opening requiring a repair of the housing....easy, but a pain)
However, my codes are all back. It has not acted up all at once though suggesting maybe the cleaning was partially helpful. The modules are all consistent with what they report, that is, U1016 H, and U1096 H.
Tonight I got under the driver side dash looking to evaluate the DLC(Data Link Connector) as logic suggests a wiring/COM break far upstream. I say that because I have checked and rechecked the grounds. The DLC is not likely, for the following reason. There is about 8 inches of wiring from the DLC before it enters a wrapped harness and the travels across the dash to the BCM area in the passenger footwell. I just refuse to believe that this wrapped harness has suddenly developed a broken wire. No water damage (I live in NEVADA..dry as a bone), the car has never been wet inside and the wiring harnesses remain untouched since March 29, 2001(her birthday).
Given what has been checked I am leaning towards either the BCM or the PCM, with PCM first on my list. Bill and I had discussed this earlier, and we both subscribe to the idea of thinking a problem through instead of just changing out "maybe this, maybe that" and running up a big tab on top of the time. However, at some point, one must admit that he can not narrow the list any further, and a decision must be made. So I ask those of you have followed, please put in your two cents.
Curious why you would choose PCM over BCM as first choice if you have to replace something? I would think the opposite since you have so many BCM functions affected. In your post you never mentioned whether the car will run, only that you have BCM (interior) related functions going haywire when the car is on.
I don't imagine you are using the DLC, correct?
Too bad you couldn't borrow a known good working PCM and BCM to try......
Ron
As for the PCM over BCM .....there is an interesting chart in the service manual (Section- Body and Accessories, Data Link Connectors, Ch.8-173) that describes the method for determining which module is not communicating. Specifically based on DTC U1001-U1254. The last 3 numbers in the DTC identify the module. All of us know that U codes are communication issues, but with this chart one can see from where the issue comes........for instance (based on my two consistent and persistent recurring codes):
U1016-------- U1 016 016 is PCM
U1096-------- U1 096 096 is IPC
SDM, BCM, TCS, RDCM, LDCM, SCM, HVAC, AND BoRfa all show U1016, meaning (and this is where I have trouble, as the manual is not clear) that these modules are not communicating with the PCM. However, several of them also show (U1096) suggesting loss of com with IPC. Occ all of them show both further confusing the picture. However in those that show loss on both PCM and IPC, the IPC itself is showing U1016! So at this point my best guess is that the IPC has the main problem. The above mentioned page in the manual is chock full of helpful tidbits of info that can further help or hinder.........but I invite further discussion.
Ron
Yes, borrowing one of those would be a huge help. As for the DLC, I used it to scan at first, more for confirming than anything else.......but several times the tool would not connect with the car computer.....still not sure as to why as the connector and pins where in very good shape. My concern at that area is that since my issues are hitting modules from BOTH star connectors, I felt the only place I could be having a short or open is at the point before the wiring branches off to the connectors, which seemed close to the DLC though I never saw the branching point as it was buried in wrapped harness.
Drive it with those modules isolated and see if that changes symptoms. Those modules will indicate NO COMMS while they are isolated.
If that doesn’t change the symptoms, carefully examine the wiring at the PCM and make sure that you don’t have ACID DAMAGE from a past battery leak.
If you don’t have any acid damage, start pulling the other monitored modules one at a time to see if they are corrupting the serial data line.
Modules like HVAC, Radio, SDM etc...........
I have not yet been able to try Bill's suggestion as when I pulled the front seat to check the SCM I found a broken bracket that needs to be custom made. So for the moment, no seat in the car! What next?
BTW Bill.......how do I isolate modules one at a time?
Re-read your post again. If there is a connector/splice at that location and all the colors match the various schematics, that should be it. The actual ground wire should route thru the firewall and terminate at G104 below the battery area.
Thanks. It's strange. The drawing I posted does not show it, but there is a splice pack about 1.5ft from SP202. Which SP is it?
Now I understand its not about me but, it seems odd to run that all the way to the other side of the car for a ground......IPC to right front rail. However your schematic does support it. I have had the idea to pull the IPC out and have a look......maybe now is the time, since I have plenty of room up there with the seat out.
I'll check it out tonight after work. Thanks for sticking with the post....you have been very helpful, as has Bill and the others.
If I am correct the car runs "fine" but you are getting communication "digital/serial bus" issues. Is there anything that you can tell that is "not working right"? If cleaning the BCM resolved most of your issues, my guess is that it may still be at the root of your issues. With that said let Bill be the "big dog" on this so you stay focused on what he says since he has far more experience that me in this area. It can be solved, it's just metal and wires. Sam
Bill felt it was in the ignition somewhere. I had started with the unsuccessful repair of my ignition switch and then replaced it with a new one. This did not seem to have any impact. Then Bill suggested the anti theft system. We reset a few things and the crazy "sweeps" disappeared. Everything else remains thus far. Cleaning the BCM seemed to help....I could go longer intervals between code mayhem (20 mins vs 5) but when they returned they were ALWAYS the same codes from same modules and the ABS/TC DIC warnings. All U codes and all will be U1016 and U1096 which is loss of com with PCM and IPC respectively. So, that's the run down refresher.
PS: We could see if Pope Francis would bless the car? That could be a quick fix. You must be a real trooper, I have not noticed any frustration in your posts. I imagine there has been some cussing in the cabin????
Turned out to be badly deformed female pins in the IGNITION SWITCH Harness connectors.
Disconnect the two ignition switch power connectors and carefully examine the female pins.. Ecpecially the ones that supply 12 VDC power to the switch.
See post 41 for pictures of damaged pins:
http://forums.corvetteforum.com/c5-t...and-p1153.html
Bill
Bill
Not to detract from the thread but I'm having many of the same codes the OP has popping up on a regular basis, although I'm not experiencing any system failures, and (knock on wood) everything works just as it should. Two of the codes I am getting are short to ground for both of the front turn signals, and these codes showed up after I cleaned my ignition switch according to your ignition switch thread instructions. Where might I check for the cause of these two particular codes? Is it the ground under the passenger side A-pillar?
Does your DRLs function properly for both sides as a DRL and a blinker when you turn the blinker on??
There are TWO relays involved in the circuit, two light bulbs the multifunction switch and the BCM its self and a few ground connectors.
Has your BCM ot the passengers footwell ever been wet???
Bill
DTC B2578 Right Front Turn Signal Monitor Circuit
Circuit Description
The BCM monitors the RF turn signal circuit in order to determine the status of the turn signal switch. If the BCM detects an oscillating voltage on the RH turn signal monitor circuit, the BCM interprets this as a RF turn signal ON request from the turn signal switch. The BCM will de-energize the RH DRL relay, which will disable the RF turn signal lamp (which is ON for the DRL), thus allowing the RF turn signal to flash. If the BCM does not detect an oscillating voltage on the RH turn signal monitor circuit, the BCM interprets this as the RF turn signal being OFF. The BCM will then energize the RH DRL relay and continue normal DRL operation. The BCM monitors the RH turn signal monitor circuit and determines how long voltage is applied. If the voltage is applied for longer than expected, a malfunction is present and a DTC will set.
Conditions for Setting the DTC
The BCM detects continuous battery voltage on the RH turn signal monitor circuit.
The condition must be present for longer than 5 seconds.
Action Taken When the DTC Sets
Stores a DTC B2578 in the BCM memory.
No driver warning message will be displayed for this DTC.
Conditions for Clearing the DTC
This DTC requires an ignition cycle in order to change from current to history.
The BCM no longer detects continuous battery voltage on the RH turn signal monitor circuit for longer than 5 seconds.
A history DTC will clear after 50 consecutive ignition cycles if the condition for the malfunction is no longer present.
Use the IPC clearing DTCs feature.
Use a scan tool.
Diagnostic Aids
The following conditions may cause an intermittent malfunction:
There is an intermittent short to voltage in the RH turn signal monitor circuit.
The turn signal switch or the hazard switch is internally shorted or is sticking.
The BCM needs to detect voltage oscillations on the RH turn signal monitor circuit in order to de-energize the RH DRL relay. If the BCM detects continuous voltage on the RH turn signal monitor circuit, the BCM interprets this as a short to voltage. The BCM will continue with normal DRL operation, and the RF turn signal will remain inoperative.
If the DTC is a history DTC, the problem may be intermittent. Perform the tests shown while moving related wiring and connectors. This can often cause the malfunction to occur. Refer to Intermittents and Poor Connections .
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
Tests if a DTC B2583 is stored in the BCM. If both the RH and LH turn signal monitor DTCs are stored, test the hazard switch and related circuits for a short to voltage.
Tests if the BCM is receiving oscillating voltage on the RH turn signal monitor circuit. If the test light is ON steady, the BCM will set a DTC B2578.
Tests if the turn signal switch or related circuits are shorted to voltage.
Tests if the hazard switch or related circuits are shorted to voltage.
Tests if the instrument panel cluster turn signal indicator is shorted to voltage.
Tests if the body control module is shorted to voltage.
When the BCM is replaced, use a scan tool to perform the BCM RPO Reprogram procedure. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Step
Action
Value(s)
Yes
No
1
Did you perform the BCM Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Body Control System
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Select the BCM display DTC function on the scan tool.
Does the scan tool display DTC B2583?
Go to Step 10
Go to Step 3
3
Turn OFF the ignition.
Disconnect the RH DRL relay.
Probe the RH turn signal monitor circuit at the RH DRL relay with a test lamp that is connected to a good ground. Refer to Power Distribution Schematics in Wiring Systems for electrical center circuit identification.
Turn ON the RH turn signals
Does the test lamp turn ON and OFF with the RH turn signals?
Go to Step 13
Go to Step 4
4
Does the test lamp remain illuminated?
Go to Step 5
Go to Turn Signal Lamps Inoperative
5
Disconnect the turn signal switch.
Go to Step 6
Go to Step 9
6
Disconnect the hazard switch.
Go to Step 7
Go to Step 10
7
Disconnect the instrument panel cluster.
Go to Step 8
Go to Step 11
8
Disconnect the body control module.
Go to Step 12
Go to Step 14
9
Repair a short to voltage in the turn signal switch circuit. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 15
10
Repair a short to voltage in the hazard switch circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 15
11
Repair a short to voltage in the instrument panel turn signal indicator circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 15
12
Repair a short to voltage in the turn signal monitor circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 15
13
Replace the RH DRL relay. Did you complete the replacement?
Go to Step 15
14
Important
Perform the BCM RPO Reprogram procedure. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Replace the BCM. Refer to Body Control Module Replacement .
Go to Step 15
15
Use the scan tool in order to clear the DTCs .
Operate the vehicle within the Conditions for Setting the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Document ID# 581020
2000 Chevrolet/Geo Corvette
DTC B2583 Left Front Turn Signal Monitor Circuit
Circuit Description
The BCM monitors the LF turn signal circuit in order to determine the status of the turn signal switch. If the BCM detects an oscillating voltage on the LH turn signal monitor circuit, the BCM interprets this as a LF turn signal ON request from the turn signal switch. The BCM will de-energize the LH DRL relay, which will disable the LF turn signal lamp (which is ON for the DRL), thus allowing the LF turn signal to flash. If the BCM does not detect an oscillating voltage on the LH turn signal monitor circuit, the BCM interprets this as the LF turn signal being OFF. The BCM will then energize the LH DRL relay and continue normal DRL operation. The BCM monitors the LF turn signal monitor circuit and determines how long voltage is applied. If the voltage is applied for longer than expected, a malfunction is present and a DTC will set.
The BCM detects continuous battery voltage on the LH turn signal monitor circuit.
Stores a DTC B2583 in the BCM memory.
The BCM no longer detects continuous battery voltage on the LH turn signal monitor circuit for longer than 5 seconds.
Use a scan tool.
Diagnostic Aids
There is an intermittent short to voltage in the LH turn signal monitor circuit.
The turn signal switch or the hazard switch is shorted internally or is sticking.
The BCM needs to detect voltage oscillations on the LH turn signal monitor circuit in order to de-energize the LH DRL relay. If the BCM detects continuous voltage on the LH turn signal monitor circuit, the BCM interprets this as a short to voltage. The BCM will continue with normal DRL operation, and the LF turn signal will remain inoperative.
Test Description
Tests if a DTC B2578 is stored in the BCM. If both the LH and LH turn signal monitor DTCs are stored, test the hazard switch and related circuits for a short to voltage.
Tests if the BCM is receiving oscillating voltage on the LH turn signal monitor circuit. If the test light is ON steady, the BCM will set a DTC B2583.
Step
Action
Value(s)
Yes
No
1
Go to Step 2
2
Go to Step 10
Go to Step 3
3
Disconnect the LH DRL relay.
Probe the LH turn signal monitor circuit at the LH DRL relay with a test lamp that is connected to a good ground. Refer to Power Distribution Schematics in Wiring Systems for electrical center circuit identification.
Turn ON the LH turn signals
Does the test lamp turn ON and OFF with the LH turn signals?
Go to Step 13
Go to Step 4
4
Go to Step 5
5
Go to Step 6
Go to Step 9
6
Go to Step 7
Go to Step 10
7
Go to Step 8
Go to Step 11
8
Go to Step 12
Go to Step 14
9
Go to Step 15
10
Go to Step 15
11
Go to Step 15
12
Go to Step 15
13
Replace the LH DRL relay. Did you complete the replacement?
Go to Step 15
14
Important
Go to Step 15
15
Does the DTC reset?
Go to Step 2
System OK
Document ID# 581021
