transmission problem need advice??
Old Feb 18, 2013 | 06:37 PM
427TTA4's Avatar
427TTA4
Default transmission problem need advice??
So my transmission issue started about a month ago when for some reason all of a sudden my car wouldn't go into 5th it just starts grinding when I release the clutch.The 5th gear does not hesitate at all no pops,grinds, or choppy effort to get it in but ONLY when I release the clutch its starts grinding.One more thing I want to add is that if I shift into 5th below 30mph it works perfectly fine like if the issue does not exist so it has me buzzed out.So any advice will be appreciated before I shop for a new tranny.Thanks for the advice!!
Old Feb 19, 2013 | 12:36 AM
427TTA4's Avatar
427TTA4
Car is a 99 C5 MN6
Old Feb 19, 2013 | 11:18 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
I had the same problem, 99 6mm, 140,000 miles. Contact RPM Transmjssions @ 1-800-406-1109. They will diagnose the problem and advise remedy.
Been there did that ! Good Luck !
The Big Guy !
To transmission problem need advice??
