Questions re a 2002 C5
Old Jun 15, 2002 | 02:54 PM
00PewtVetteCpe's Avatar
00PewtVetteCpe
Default Questions re a 2002 C5
My 2000 A4 coupe was stolen about two months ago. I'm buying a 2002 A4 in a few days for a good price and very low miles. The 2002 has the optional high polished wheels which I want to replace with factory magnesium wheels. Can I use the existing sensors for the mags? Another question - Should I leave the MAF alone on the 2002 or not? Is there anything I should know about the 2002 setup which is different from a 2000? Thanks in advance, Rick
Old Jun 15, 2002 | 03:42 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Questions re a 2002 C5 (00PewtVetteCpe)
the 2002's (and maybe 2001) have the larger diameter MAF from the factory.
Old Jun 15, 2002 | 06:17 PM
bub's Avatar
bub
Default Re: Questions re a 2002 C5 (Mike Mercury)
RE "anything you should know about '02 vs. '00"
You'll notice the difference!
WRT sensors. Note that '02 sensors are different from '00. They will fit the wheels (they are smaller) but are not compatible with the cars DIC module (will throw a trouble code - i.e. they are not interchangeable between years).
The HP sensors will work on the mags as long as they are the same '02 year.
'02 sensors will transmit a pressure signal without the car in motion (unlike the '00 you are used to).
-CKB
[Modified by bub, 4:19 PM 6/15/2002]
Old Jun 15, 2002 | 11:53 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Beginning in 01 the LS1 and LS6 received the Larger diameter truck maf.
It is a one piece MAF that does not use MAF ends like 97-00.
Many remove the screen in the MAF by cutting it out.
The 01+ MAF also incorporates the intake air temp sensor in the housing, making it a 5 wire harness instead of three.
[Modified by kewlbrz, 10:00 PM 6/15/2002]
To Questions re a 2002 C5
