Vararam or Zip Tie mod
Is the Zip-Tie mod and Flip-Tie mod the same thing because I have heard both terms used?
I’m about to order my Vararam but don’t want to if I will get the same performance from the zip-tie mod.
Has anyone had both? If so which do you like better?
Also if I order the Vararam is the power duct worth the extra $80-100 or is it jut for looks.
Thanks in advance
The GOAL of a cold air system is to be able to collect cold fresh air. If you do the FLIP TIE MOD and cut the shroud so the filter gets cold fresh air,,, you will gain the benifits. I can not tell you IF,, you will equal /exceed or lose any HP/TQ one way or another between the home made or designed system. Hell,, try the FREE mod and if you dont see any gain,, then get the VARARAM.
Bill
Bill
The bad fit and finish and the general cheapness of a Vararam system far outweighs the perceived benefits IMHO. You would think that after all these years of people complaining, they would have improved it. Guess not.
At least the zip-tie mod is free if you decide to go that route.
Bottom line: I wanted the zip-tie mod on my 2001 C5 Vert but with an OEM look !!! Plus I wanted to recycle those plastic buckles!
I came up with a way to re-engineer the OEM parts to do the Corvette AirFilter "zip-tie" mod but without zip-ties! !!!
OK,OK, I used two small zip ties (as seen in the pics) just to hold the buckles down just in case! - - really not needed!
Not too hard:
1) I shortened and bent new ends on the (2) metal straps. Get one right and copy the bends side-by-side with the other strap.
2) I shaved some of the rib height off the back of the (2) plastic buckles.
3) I unclipped the grab handle from the plastic frame that clamps down on the filter.
4) I removed the floppy AirBox cover from the car (two torx screws) - - mine already had a Z06 snorkle cover (see picture)? Is this a prior owner mod or 2001 OEM?
What do you think? Looks OEM compared to using big zip ties?
Right?
My only remaining issue is how to better connect the modified airbox to the car ??? Right now it's only held in place by hoses - - it can move a little side-side. Ol' zip tie mod would present same issue I think! Ideas???
Take a look at the following links for the flip tie.
https://www.corvetteforum.com/forums...-write-up.html
https://www.corvetteforum.com/forums...a-success.html
The first link also has an attached pdf file that can be downloaded.
Good luck.
Generally speaking many who drag race like the VeraRam, Open Road Racers like the Callaway type, and road racers like the Open license frame method. For normal street driving they all work. However, if you do change the coolness of incoming air and/or alter the path, I would suggest a good street tune. ECS, COW and numerous other forum vendors can help you there.
