Dampener
Old Feb 27, 2013 | 12:41 PM
jbhesse's Avatar
jbhesse
Default Dampener
Is the item bolted on the left side of rear end housing on a std. C5 called a harmonic balancer? I have a problem with one and am not sure I am using the correct name to describe it. It is two steel donuts rubber mounted and bolt on with an angle iron and two bolts.
Old Feb 27, 2013 | 01:53 PM
3boystoys's Avatar
3boystoys
Harmonic balancer is on the FRONT of the engine, at the end of the crankshaft.
Old Feb 27, 2013 | 02:13 PM
BigGun's Avatar
BigGun
I believe it is more of a vibration dampener. I don't know what GM calls it but a parts man should be able to help you.
Old Feb 27, 2013 | 03:00 PM
NukeC5's Avatar
NukeC5
Yes, its mostly known as the differential vibration damper.
Old Feb 28, 2013 | 02:29 PM
slvr bulit's Avatar
slvr bulit
Old Feb 28, 2013 | 04:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What sort of issue are you having with it? What year C5
What modifications do you have??
Old Feb 28, 2013 | 05:01 PM
wcsinx's Avatar
wcsinx
That thing will not cause the issue you posted in your other thread
http://forums.corvetteforum.com/c5-t...vibration.html
Old Mar 2, 2013 | 12:30 PM
jbhesse's Avatar
jbhesse
C5 is a 2000, there are no modifications to it. Std. Small V8, automatic, 53000 miles. Vibration at 850-900 rpms, more prevalent when the A/C is on.
Old Mar 2, 2013 | 10:16 PM
NukeC5's Avatar
NukeC5
Its highly unlikely that the differential damper is faulty. Deteriorating T-Tube rubber components and the engine harmonic damper are far more troublesome. What makes you think its the problem?
I think these cars just vibrate at idle. I experience it every time I come to a stop. Its annoying, but about the only thing you can do is a tune up and run good spark plugs to settle the engine down.
To Dampener
