Does anyone know the Torque soecs for the exhaust manifold studs that bolt the manifold to the cylinder head....I broke one and had to use an easy out to remove it...and don't want to repeat that, but I have a slightly warped header surface and need to be able to tighten it enough to close the minor exhaust leak.
The torque specs from the 2001 FSM's are: 11 lb ft on the first pass, and 18 lb ft on the final pass.
Begin at the center bolts, and alternately tighten the bolts from the center outward.
Rather than over tightening the bolts to close the warped header flange surface, try using two manifold gaskets instead. It will usually do the trick if the warpage is not too excessive.
The bolt TORQUE is determined by the bolt material, thread pitch and how much it takes to apply the correct clamping force to the fastener to achieve the correct bolt stretch AND what determined the bolt screws into. I.E. Aluminum
Clamping a cast iron manifold or a SS Header flange shouldn’t make any difference. It still 11 first pass/ 18 finial pass.
It is normal to select the torque based on the gasket design/material in this situation since the head material is the same and the header material is equivalent. You can call LG and confirm.
PS: Using 2 OEM style gaskets (if you have some warpage) should not really affect the torque you use in my opinion.
Did not see Bill's comment until I posted, but also agree with his input.
Reason: Add comment
You might lose a thread or two of bolt engagement, due to the extra gasket thickness, but the extra gasket itself should have little effect on the final clamping force at the specified torque value.
I would probably use studs and nuts, instead of bolts, to allow the full thread engagement with the extra gasket thickness.
thanks everyone...The parts store near me only had one set of Felpro gaskets...Out of expedience I ended up using the stock metal gaskets on the side toward the manifold (LT headers), and the felpro gasket on the side towards to heads....I also tightened from the center outward, and very gently went to about 24 FPT on the second pass on the center bolts...after two days of driving no more leaks so far.
The two gasket solution, and tightening from the center bolts outward seems to have done the trick, after another week of spirited driving I'll know for sure, but for now its holding up.
Note to self, (and everyone else): Tighten the header flanges to the heads from the center outward ;-)
My issue was where the LT Flange bolts to the heads, had a slightly warped flange.
So you asked for the correct torque specs, and then you over torqued them anyhow.......oh we'll.
lol
yep
needed a benchmark to have an idea of how tight I could go without breaking the bolt again...had to go over a bit because even with two gaskets there was still a tiny leak.
All good now.
Sometimes you just have to throw in a little creativity to make it work.
