Ticking...
Old Mar 5, 2013 | 08:06 PM
Firstorlast's Avatar
Firstorlast
Default Ticking...
Noticed recently when I pull into my garage I hear a loud ticking. I can barely hear it in the morning when I start it up but as the car warms up it gets louder. 99 btw.
I also noticed that when I go for a 30 or 40 min highway run (80mph avg maybe a little faster here and there) that the ticking will be pretty much gone when I get home. It seems to happen when I do my 15 min drive to and from work.
It doesn't sound anywhere near as bad as a valve tapping, I've listened to a bunch of videos of LS1s with bad valves.
Some one mentioned it could be an exhaust leak and my flowmasters are rusting away, theres a loose baffle that rattles ect, I'm odering a new setup in a week or two. Idk
Any help would be appreciated. I have a warranty that covers everything BUT it has a $500 deductable so I'd rather ask you guys first. I also believe some of you are probably even MORE knowledgeable.
Heres a video I took tonight with my phone when I got home from work, it can be heard just as I hear it no changes from the recording.
Old Mar 5, 2013 | 08:34 PM
Firstorlast
I'd also like to specify only mods to my knowledge - exhaust.
Also I haven't been abusive, I've only had it for afew months. I literally haven't even done a burn out yet. I've punched it a few times, not recently. I'm saving the motor for when I get full exhaust cam ect. So when I got it, it sounded great and now after two months of babying and a recent oil change, spark plug/wire change I get this.. ???
Old Mar 6, 2013 | 11:05 AM
slvr bulit's Avatar
slvr bulit
Kinda sounds like a exhaust leak to me. Have you tried to snug up the exhaust manifold bolts? How many miles on it? Also the pullies that the serpentine belt goes around can make funny noises, take the belt off and spin all of them by hand. But honestly it does sound like a exhaust leak, it could even have a small leak by the AIR tubes that go in the manifold.
Old Mar 6, 2013 | 01:24 PM
JetMechZ16's Avatar
JetMechZ16
This is how I pinpointed an exhaust leak on an old 440 magnum engine i had. Some people my not like doing this but it worked fine for me.
Start the engine while it's cold and exhaust manifolds have not heated up yet. With a water hose on lightly run the stream of water across the exhaust manifold all over until you hear the ticking stop. When the sound stops is where the leak is.
If it's not and exhaust leak then this won't find it.
I don't recommend doing it to a hot manifold as it could warp or crack.
Old Mar 6, 2013 | 02:35 PM
Firstorlast
52k
Yeah I really hope its just a leak.. then its a hunt instead of a small fortune. Anyone have any tips for pinpointing a leak??? I do plan on removing my exhaust this weekend because it has a rattle inside the muffler and its ridiculously loud. Damn aluminum flowmasters.. planning on odering a new setup in about a week.
Allthough if I have a manifold leak and require new gaskets I might have to change plans and just oder cat'ed LTs and run no exhaust for awhile..I do live in FL now.. its probably frowned upon to have mufflers on something like a vette.
Old Mar 6, 2013 | 03:17 PM
JetMechZ16's Avatar
JetMechZ16
Old Mar 6, 2013 | 05:47 PM
tlove32's Avatar
tlove32
That sounds like it's valvetrain related. It's too slow to be piston slap
Old Mar 6, 2013 | 06:17 PM
Firstorlast
Thanks Ill definitely consider that when I get to it this weekend
Old Mar 6, 2013 | 06:18 PM
Firstorlast
Sh*t dont say that lol... I'm hoping its not.. all the other youtube videos of LS engines with valve problems sound ALOT worse.
Old Mar 27, 2013 | 10:32 PM
tmarquez's Avatar
tmarquez
4th Gear
I have an 05 that started making that ticking sound on a couple occasions. The part that has me confused is mine only lasted for a few minutes after I ran it on the freeway for about 30 mins each time.
Old Mar 27, 2013 | 10:41 PM
Sideswipe505's Avatar
Sideswipe505
Does the ticking increase in volume when you're on the throttle?
Old Mar 27, 2013 | 10:44 PM
tmarquez's Avatar
tmarquez
4th Gear
Yes it does but then goes away after a few minutes. Ironically it has only happened twice in the morning but not in the afternoon.
Old Mar 27, 2013 | 10:49 PM
Sideswipe505
It doesn't sound like an exhaust leak if its going away. I'd start looking at valve train since it doesn't seem to be fast/loud enough to be piston slap.
Old Mar 27, 2013 | 11:46 PM
sircampsalot2's Avatar
sircampsalot2
Sounds like a Donut gasket or Manifold gasket. After it heats up it stops so thats what i would think it is. Hows your oil pressure in the morning and after youve driven? look normal? I wouldnt think it would be not getting enough oil to the top of the engine or it would sound alot worse. Doesnt sound like a lifter tapping either to me.
Old Mar 27, 2013 | 11:50 PM
tmarquez's Avatar
tmarquez
4th Gear
I will monitor the oil and see if it is different in the AM comp to the PM
Old Mar 28, 2013 | 02:34 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
I had a similar sound that went away after it warmed up. Went on for a couple months and started getting worse. Could not pin point it so I tore the engine down. Turned out that it was a lifter. The bearings in the roller felt smooth when rolling it but if you push hard while rolling it it got real rough and crunchy. It made a line on the cam like it would lock up every now and them. Nothing major just a smooth line. Glad I tore it down before something blew.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Mar 28, 2013 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To Ticking...
Old Mar 28, 2013 | 07:05 PM
Firstorlast
Finally put my BBK shortys and OBX exhaust on last weekend. Happy to say the ticking noise is gone, car sounds perfect now, couldn't be happier with the difference the mods made. Totally different car, sounds like a monster.
Pretty sure the exhaust leak was coming from the drivers side manifold to cat gasket. Car has 52k, the header to cat gaskets were pretty bad. Large rust cracks and holes, no question they were leaking.
Old Mar 29, 2013 | 01:00 PM
BitViper's Avatar
BitViper
Yeah... thats a leak or a spark plug wire? Is there a slight stumble at any time when the car runs up... Check the "AIR" tube.. nobody ever checks thoes.. most check the gaskets on the heads..
Old Mar 29, 2013 | 03:32 PM
sircampsalot2
Glad you found it Have fun with your new sound!
